1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Using asynDriver outside of an EPICS IOC
To: Jimmy Johnson <[email protected]>, EPICS mailing list <[email protected]>, Mark Rivers <[email protected]>
Date: Mon, 26 Jan 2015 10:34:54 -0800
Mark,
I am interested in that topic as well.
I just want to understand correctly.
Are you saying that an EPICS database can be populated with data coming from another control system?
Or are you saying that asyn can be used to interface with hardware in any other control system?
In this latter case, why even depend on libCom from the EPICS base then?
Emmanuel Mayssat
http://www.epicsqt.org
To: [email protected]
Subject: Using asynDriver outside of an EPICS IOC
Date: Thu, 22 Jan 2015 18:48:11 +0000
Has anyone used the asynDriver framework outside of an EPICS IOC and if so would you be willing to share your experience?
Thanks
Jimmy Johnson
Re: Using asynDriver outside of an EPICS IOC Andrew Johnson
RE: Using asynDriver outside of an EPICS IOC Mark Rivers
Using asynDriver outside of an EPICS IOC Jimmy Johnson
Prev: RE: Alarm annunciation with ALH and other PC based systems Emmanuel Mayssat
Next: Re: Using asynDriver outside of an EPICS IOC Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Using asynDriver outside of an EPICS IOC Jimmy Johnson
