1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Alarm annunciation with ALH and other PC based systems
To: Maren Purves <[email protected]>, EPICS mailing list <[email protected]>
Date: Mon, 26 Jan 2015 10:27:58 -0800
The ALH indeed works well.
But I am not sure this is the most reliable solution for 3 reasons.
1/ The ALH runs on the client PC
2/ The ALH runs on PC hardware.
3/ The ALH can be turned off by operators. (speakers can simply be turned off to make the alarm system fail)
To solve this without the ALH, you need to run a back-end service (i.e. on the server side) that filters and dispatches the alarms to dedicated hardware.
This is already implemented in BEAST, the CSS alarm handler.
A similar architecture is intended to be used for the one part of EPICS Qt.
Emmanuel Mayssat
http://www.epicsqt.org
> Date: Tue, 20 Jan 2015 13:59:32 -1000
> From: [email protected]
> To: [email protected]
> Subject: Re: Alarm annunciation with ALH and other PC based systems
> ALH or something else, sensors can fail too, it doesn't have to
> have anything to do with what you're running or what you're
> running it on. We recently had an almost whole system shutdown
> (thankfully the instruments stayed cold) when the UPS failed
> to last through a power outage.
> The old ALH works quite well :)
> Maren
Re: Alarm annunciation with ALH and other PC based systems Maren Purves
Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
RE: Alarm annunciation with ALH and other PC based systems Emmanuel Mayssat
Prev: RE: Checking which record triggered processing Mooney, Tim M.
Next: RE: Using asynDriver outside of an EPICS IOC Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
Next: Re: Alarm annunciation with ALH and other PC based systems Maren Purves
