1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Alarm annunciation with ALH and other PC based systems
To: [email protected]
Date: Fri, 23 Jan 2015 09:45:29 -0800
Thanks for all of your comments.
While my original question was about the use of the 'old ALH' application on a PC (running Linux, which I don't think I originally mentioned) in a control room setting only, I appreciate the comments from others regarding other alarm annunciation techniques. Those comments will be sure to generate some dialog here, as well.
My present strategy under initial investigation is to use USB speakers. In that scenario, I think we can use the console PC host to control the volume via a 'hidden' tool making inadvertent volume adjustment much less likely. It certainly appears that we can monitor the volume, and also monitor the connection status of the speakers through software. Power is supplied to the speakers through the USB interface, so that eliminates the possibility of (hidden/silent) power source faults. This should allow us to have a secondary alarm handler somewhere, which is dedicated to monitoring the primary alarm handler.
For the record, we are using the ALH application now and in the immediate future, however this is expected to change at some time not too distant from now. The control room console that runs the ALH application is pretty much dedicated to that purpose. Personnel safety is managed independently from the control system here, and radiation alarms & oxygen deficiency alarms use industrial alarm annunciators that are not part of the primary control system, other than supervisory monitors.
   ---   rod.
On 01/20/2015 03:59 PM, Maren Purves wrote:
ALH or something else, sensors can fail too, it doesn't have to
have anything to do with what you're running or what you're
running it on. We recently had an almost whole system shutdown
(thankfully the instruments stayed cold) when the UPS failed
to last through a power outage.
The old ALH works quite well :)
Maren
On 01/20/15 13:43, Emmanuel Mayssat wrote:
Interesting thread.
If I understand your email correctly, you are using the old ALH on a PC.
Well, if you are sticking with this setup then the best way may be to
dedicate a computer to run the ALH
and put it behind a glass so that no one can touch it! Put the speakers
out of reach as well.
Are you open to using something else other than the ALH?
Emmanuel Mayssat
http://www.epicsqt.org
> Date: Wed, 14 Jan 2015 13:27:14 -0800
> From: [email protected]
> Subject: Alarm annunciation with ALH and other PC based systems
> Hi All:
> Sorry that this isn't really an EPICS question, other than the tenuous
> connection via Alarm Handler.
> The question has been raised here about how to ensure that the audible
> alarms from Alarm Handler are always audible. A number of places exist
> where this can be disabled. The speakers can become faulty, the
> wall-wart commonly used to power the speakers can become
disconnected or
> faulty, the volume control on the speakers can be turned down, the host
> OS software controls can be turned down or muted either through
accident
> or software fault, audio cables can become faulty, and sound card
> hardware can become faulty. Most of these will manifest only in
silence.
> Has anyone undertaken measures to monitor any of these components in
> some way, or implemented hardware which is not subject to the common
> frailties of commodity audio equipment used for control room alarms?
> Any suggestions cheerfully accepted. Thanks.
> Rod Nussbaumer
> E-Linac Controls, TRIUMF
> Vancouver, Canada.
Alarm annunciation with ALH and other PC based systems Rod Nussbaumer
RE: Alarm annunciation with ALH and other PC based systems Emmanuel Mayssat
Re: Alarm annunciation with ALH and other PC based systems Maren Purves
Prev: Re: sequencer release 2.2.1 Benjamin Franksen
Next: Re: EPICS driver for CAENels HV-Adaptos? Weiwei Lu
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Alarm annunciation with ALH and other PC based systems Maren Purves
Next: RE: Alarm annunciation with ALH and other PC based systems Emmanuel Mayssat
