1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problems with CA
To: EPICS Tech Talk <[email protected]>
Date: Thu, 29 Jan 2015 14:35:59 +0100
What kind of IOC/OS are you trying to reach?
(I have seen IOC / LabVIEW systems on Windows that would never answer to CA nameres broadcasts, only to unicasts.)
~Ralph
On 29/01/2015 14:13, Mark Rivers wrote:
If the subnet mask and CA environment variables are OK then:
- What is the network topology between 192.168.1.1 and 192.168.1.6.  Only switches between them?
- Is there a firewall (e.g. iptables, etc.) running on either machine?
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Thursday, January 29, 2015 6:50 AM
To: Florian Feldbauer; EPICS Tech Talk
Subject: RE: Problems with CA
That should have worked.
Are you sure that you have set the subnet mask on your IOC machine correctly?
Sent: Thursday, January 29, 2015 6:44 AM
To: Mark Rivers; EPICS Tech Talk
Hey,
thanks for the answers.
Unfortunately I did not work:
Here is what I tried:
   ~ > ifconfig p3p1
p3p1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
          inet 192.168.1.1  netmask 255.255.255.0  broadcast 192.168.1.255
          inet6 fe80::213:3bff:fe0f:e7bf  prefixlen 64  scopeid 0x20<link>
          ether 00:13:3b:0f:e7:bf  txqueuelen 1000  (Ethernet)
          RX packets 39249  bytes 5375914 (5.1 MiB)
          RX errors 0  dropped 0  overruns 0  frame 0
          TX packets 192403  bytes 81244106 (77.4 MiB)
          TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
   ~ > setenv EPICS_CA_AUTO_ADDR_LIST NO
   ~ > setenv EPICS_CA_ADDR_LIST 192.168.1.255
   ~ > caget -w 20 PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom
Channel connect timed out: 'PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom' not found.
   ~ > setenv EPICS_CA_ADDR_LIST 192.168.1.6
   ~ > caget PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom
PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom 0.0489747
p3p1 is the name of the network interface to which all our EPICS IOCs
are connected...
    Florian
On 01/29/2015 12:58 PM, Mark Rivers wrote:
Is there a way to specify a subnet as address lsit for CA?
Yes.
where 192.168.1.255 is the broadcast address of that subnet.  That syntax would be correct if the subnet mask is 255.255.255.0.
From: [email protected] [[email protected]] on behalf of Florian Feldbauer [[email protected]]
Sent: Thursday, January 29, 2015 3:35 AM
To: EPICS Tech Talk
Subject: Problems with CA
Hey all,
I have observed some problems with channel access in our lab.
We have a PC with three network interfaces.
On is connected to the network of our institute (->WAN)
the other two are used for local sub nets with its own DNS/DHCP...
The used OS on this PC is Fedora 20.
On one of these local sub nets I have a running EPICS IOC.
When using caget on the PC I always get a timeout error.
Only when I specify the environment variables:
       setenv EPICS_CA_AUTO_ADDR_LIST no
caget works.
The IP addresses for the local subnet are dynamically assigned,
and I don't want to look up each time, which addresses are used....
Also I don't want to put all 256 possible addresses in the
EPICS_CA_ADDR_LIST.
Or is it possible to bind all request (from Clients as well as from
Servers) on the machine
to one specific interface?
Best regards,
Florian
Problems with CA Florian Feldbauer
RE: Problems with CA Mark Rivers
Re: Problems with CA Florian Feldbauer
Prev: RE: Problems with CA Mark Rivers
Next: Re: Problems with CA Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
