Hey,
@Ernest
I did not set ENV vars for the ports, so they should be the default ones
on both systems (5064 & 5065)
The only EPICS relevant ENV vars which are set are
EPICS_HOST_ARCH, EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST.
On 01/29/2015 02:13 PM, Mark Rivers wrote:
If the subnet mask and CA environment variables are OK then:
- What is the network topology between 192.168.1.1 and 192.168.1.6. Only switches between them?
Yes. There is only a switch between both PCs.
- Is there a firewall (e.g. iptables, etc.) running on either machine?
Yes...there WAS a firewall (firewalld) running....and the ports 5064 and
5065 were opened for TCP and UDP.
But after stopping the firewall it worked...so obviously I did something
wrong with its configuration...
Thanks for your help!
Florian
From: [email protected] [[email protected]] on behalf of Mark Rivers [[email protected]]
Sent: Thursday, January 29, 2015 6:50 AM
To: Florian Feldbauer; EPICS Tech Talk
Subject: RE: Problems with CA
That should have worked.
Are you sure that you have set the subnet mask on your IOC machine correctly?
Sent: Thursday, January 29, 2015 6:44 AM
To: Mark Rivers; EPICS Tech Talk
Subject: Re: Problems with CA
Hey,
thanks for the answers.
Unfortunately I did not work:
Here is what I tried:
~ > ifconfig p3p1
p3p1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.1 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::213:3bff:fe0f:e7bf prefixlen 64 scopeid 0x20<link>
ether 00:13:3b:0f:e7:bf txqueuelen 1000 (Ethernet)
RX packets 39249 bytes 5375914 (5.1 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 192403 bytes 81244106 (77.4 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
~ > setenv EPICS_CA_AUTO_ADDR_LIST NO
~ > setenv EPICS_CA_ADDR_LIST 192.168.1.255
~ > caget -w 20 PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom
Channel connect timed out: 'PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom' not found.
~ > setenv EPICS_CA_ADDR_LIST 192.168.1.6
~ > caget PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom
PANDA:LMD:MUPIX:HV:TLSCP:0:Vmom 0.0489747
p3p1 is the name of the network interface to which all our EPICS IOCs
are connected...
Florian
On 01/29/2015 12:58 PM, Mark Rivers wrote:
Is there a way to specify a subnet as address lsit for CA?
Yes.
where 192.168.1.255 is the broadcast address of that subnet. That syntax would be correct if the subnet mask is 255.255.255.0.
From: [email protected] [[email protected]] on behalf of Florian Feldbauer [[email protected]]
Sent: Thursday, January 29, 2015 3:35 AM
To: EPICS Tech Talk
Subject: Problems with CA
Hey all,
I have observed some problems with channel access in our lab.
We have a PC with three network interfaces.
On is connected to the network of our institute (->WAN)
the other two are used for local sub nets with its own DNS/DHCP...
The used OS on this PC is Fedora 20.
On one of these local sub nets I have a running EPICS IOC.
When using caget on the PC I always get a timeout error.
Only when I specify the environment variables:
setenv EPICS_CA_AUTO_ADDR_LIST no
caget works.
The IP addresses for the local subnet are dynamically assigned,
and I don't want to look up each time, which addresses are used....
Also I don't want to put all 256 possible addresses in the
EPICS_CA_ADDR_LIST.
Or is it possible to bind all request (from Clients as well as from
Servers) on the machine
to one specific interface?
Best regards,
Florian
| Dr. Florian Feldbauer |
| Helmholtz-Institut Mainz / |
| Johannes Gutenberg-Universität Mainz |
| Johann-Joachim-Becher-Weg 36 |
| D-55128 Mainz |
| Office: SB1 / 00-213 |
| Phone: (+49)6131 / 39-29605 |
| D-55128 Mainz |
| D-55128 Mainz |
- Problems with CA Florian Feldbauer
- RE: Problems with CA Mark Rivers
- Re: Problems with CA Florian Feldbauer
Re: Problems with CA Ralph Lange
struck sis3316 digitizer ADC data transfer with RTEMS Geon-Yeong Mun
<2015>
2025
2026
Re: Problems with CA Williams Jr., Ernest L.
<2015>
2025
2026
