1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: trouble building asyn driver on FreeBSD
To: Franklin Fuller <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 29 Jan 2015 09:51:46 -0600
Hi Franklin,
On 01/28/2015 09:02 PM, Franklin Fuller wrote:
> EPICS expects gcc, while FreeBSD ships with clang.  I installed gcc/g++
> 4.8 into /usr/local/bin and then soft-linked them to /usr/bin.  This
> allowed me to build base without any errors, but then I ran into these
> troubles with asyn.
EPICS can be built with clang (I have tested that on both Mac and
Linux), you just have to configure it properly. If new versions of
FreeBSD now use clang by default then we should change the freebsd files
in configure/os to assume that; you may be our only FreeBSD user at the
moment though, so you're going to have to help me with the changes that
are needed.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
    against your wishes, and doesn't give you the key, they're
    not doing it for your benefit.
Re: trouble building asyn driver on FreeBSD J. Lewis Muir
trouble building asyn driver on FreeBSD Franklin Fuller
Prev: Re: struck sis3316 digitizer ADC data transfer with RTEMS Michael Davidsaver
Next: Re: Problem in building EPICS J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: trouble building asyn driver on FreeBSD Mark Rivers
Next: Re: trouble building asyn driver on FreeBSD J. Lewis Muir
