Hi Franklin,
I think I see the problem.
asyn/asyn/vxi11/ contains a file called osiRpc.h
It contains these lines:
#ifdef __APPLE__
#define rpcTaskInit() 0
#endif
I suspect that is the problem. It is looking for a macro called __APPLE__ to be defined. Since your build defines freebsd try adding the following to that file:
#ifdef freebsd
#endif
I think, however, that you should be able to build with clang on Darwin, you don't need to use gcc.
From: [email protected] [[email protected]] on behalf of Franklin Fuller [[email protected]]
Sent: Wednesday, January 28, 2015 9:03 PM
To: [email protected]
Subject: Re: trouble building asyn driver on FreeBSD
Copy paste error on my part:
The error at the end is:
/usr/bin/g++ -c -D_POSIX_THREADS -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dfreebsd -D_REENTRANT -O3 -Wall -MMD -I. -I../O.Common -I. -I.. -I../../../include/os/freebsd -I../../../include -I/home/yanolab/EPICS/base/include/os/freebsd -I/home/yanolab/EPICS/base/include ../testMain.cpp
/usr/bin/g++ -o test -L/usr/home/yanolab/EPICS/modules/asyn4-23/lib/freebsd-x86_64 -L/usr/home/yanolab/EPICS/base-3.14.12.4/lib/freebsd-x86_64 -Wl,-rpath,/usr/home/yanolab/EPICS/modules/asyn4-23/lib/freebsd-x86_64 -Wl,-rpath,/usr/home/yanolab/EPICS/base-3.14.12.4/lib/freebsd-x86_64 test_registerRecordDeviceDriver.o testMain.o -ltestSupport -lasyn -lrecIoc -lsoftDevIoc -lmiscIoc -lrsrvIoc -ldbtoolsIoc -lasIoc -ldbIoc -lregistryIoc -ldbStaticIoc -lca -lCom
/usr/home/yanolab/EPICS/modules/asyn4-23/lib/freebsd-x86_64/libasyn.so: undefined reference to `rpcTaskInit'
collect2: error: ld returned 1 exit status
On Wed, Jan 28, 2015 at 7:02 PM, Franklin Fuller <[email protected]<mailto:[email protected]>> wrote:
Hello,
I'm getting the following errors while trying to build asyn on FreeBSD 10
The first warning:
/usr/bin/gcc -c -D_POSIX_THREADS -D_X86_64_ -DUNIX -D_BSD_SOURCE -Dfreebsd -D_REENTRANT -O3 -Wall -fPIC -MMD -I. -I../O.Common -I. -I.. -I../../asyn/asynDriver -I../../asyn/asynGpib -I../../asyn/drvAsynSerial -I../../asyn/interfaces -I../../asyn/miscellaneous -I../../asyn/asynPortDriver/exceptions -I../../asyn/asynPortDriver -I../../asyn/devEpics -I../../asyn/asynRecord -I../../asyn/vxi11 -I../../asyn/ni1014 -I../../asyn/devGpib -I../../include/os/freebsd -I../../include -I/home/yanolab/EPICS/base/include/os/freebsd -I/home/yanolab/EPICS/base/include ../../asyn/vxi11/drvVxi11.c
../../asyn/vxi11/drvVxi11.c: In function 'vxiCreateDeviceLink':
../../asyn/vxi11/drvVxi11.c:292:13: warning: format '%lu' expects argument of type 'long unsigned int', but argument 8 has type 'u_int' [-Wformat=]
asynPrint(pasynUser,ASYN_TRACE_ERROR,
../../asyn/vxi11/drvVxi11.c: In function 'vxiConnectPort':
../../asyn/vxi11/drvVxi11.c:878:9: warning: implicit declaration of function 'rpcTaskInit' [-Wimplicit-function-declaration]
if(rpcTaskInit() == -1) {
The final error:
I tried my best to find references to this. I see there was some issues with mac os x and their RPC a long while ago, but I've built recent versions of asyn on os x without troubles. Typing "man rpc" into os x and freeBSD give similar man pages, so something is there for both of them.
Perhaps the only fishy thing is this:
EPICS expects gcc, while FreeBSD ships with clang. I installed gcc/g++ 4.8 into /usr/local/bin and then soft-linked them to /usr/bin. This allowed me to build base without any errors, but then I ran into these troubles with asyn.
Ideas?
~Franklin
- trouble building asyn driver on FreeBSD Franklin Fuller
- Re: trouble building asyn driver on FreeBSD Franklin Fuller
Re: Problem in building EPICS Rahul Jain
<2015>
2025
2026
Re: trouble building asyn driver on FreeBSD Andrew Johnson
<2015>
2025
2026
