Hello,
When I just run 'make' without the 'sudo', I get following error message:-
make -C ./configure install
make[1]: Entering directory `/opt/epics/base-3-14-11/configure'
perl ../src/tools/makeMakefile.pl O.linux-x86 ../..
Cannot create O.linux-x86/Makefile at ../src/tools/makeMakefile.pl line 41.
make[1]: *** [O.linux-x86] Error 2
make[1]: Leaving directory `/opt/epics/base-3-14-11/configure'
make: *** [configure.install] Error 2
As you suggested, I tried to build the latest version 3.14.12.4 by using
'make' without the 'sudo' and it also gave the same above mentioned error
message, but when I used 'sudo make' it was successfully built and
installed.
My directory for the EPICS installation is as follows:-
/opt/epics/base-3.14.12.4
I doubt that 'sudo' is required because I am building EPICS Base in /opt
directory. Please comment on this.
I am trying to build "Libera EPICS Drivers (ver-2.05.2, downloaded from
http://controls.diamond.ac.uk/downloads/other/libera/index.php)", in which
they recommend to build old version of Base 3.14.11. Actually I am a
beginner in EPICS and don't know much about the compatibility of versions.
Please offer your valuable comments on this.
Rahul Jain
> ---------------------------- Original Message ----------------------------
> Subject: Re: Problem in building EPICS
> From: "Johnson, Andrew N." <[email protected]>
> Date: Wed, January 28, 2015 11:45 am
> To: "Rahul Jain" <[email protected]>
> Cc: "EPICS mailing list" <[email protected]>
> What happens if you just run 'make' without the 'sudo' (which you should
> not be using, Base does not need to be built as root)?
> Are you building an old version of Base for any specific reason? The
> latest version is 3.14.12.4 and contains various advances and bug fixes
> since 3.14.11. The Channel Access network protocol is compatible across
> different versions.
> - Andrew
> Sent from my iPad
>> On Jan 27, 2015, at 11:26 PM, Rahul Jain <[email protected]> wrote:
>> Hello
>> I am trying to build EPICS base 3.14.11 on linux-x86 (32 bit) but when I
>> run sudo make command, I get following error:
>> confiugure/CONFIG:55: configure/os/CONFIG.unsupported.Common: No such
>> file
>> or directory
>> *** No rule to make target 'configure/os/ CONFIG.unsupported.Common'.
>> Stop
>> I have used following configuration set up for crosscompiling EPICS
>> Set up of configure/CONFIG_SITE script
>> CROSS_COMPILER_TARGET_ARCHS=linux-arm
>> CROSS_COMPILER_HOST_ARCHS=linux-x86
>> SHARED_LIBRARIES=NO
>> STATIC_BUILD=YES
>> Our cross-compiling toolchain is in
>> $HOME/local/x-tools/arm-unknown-linux
>> gnueabi, so I used following configuration:-
>> Set up of configure/os/CONFIG_SITE.linux-x86.linux-arm
>> GNU_DIR = $HOME/local/x-tools/arm-unknown-linux gnueabi
>> GNU_TARGET = arm-unknown-linux gnueabi
>> I have also tried setting up EPICS_HOST_ARCH environment variable
>> seperately by using following command:
>> export EPICS_HOST_ARCH=linux-x86
>> I am still getting same error message, Please solve my above query.
>> Thanks
>> Rahul Jain
- Re: Problem in building EPICS J. Lewis Muir
- Re: Problem in building EPICS Johnson, Andrew N.
RE: trouble building asyn driver on FreeBSD Mark Rivers
RE: caQtDM Zai Wang
<2015>
2025
2026
<2015>
2025
2026
