1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: caQtDM
Date: Thu, 29 Jan 2015 04:35:59 +0000
Hi Anton,
The edl2ui will be a very useful tool for EPICS Qt application development. A year ago,  I wrote a prototype tool for mapping your caQtDM widgets to EDM widgets as much as possible, but it is not in great details as yours. At that time, I thought there should be some potential users up there. I would suggest to create a better mapping table of your caQtDM functionality coverage to MEDM and EDM so that potential users will see easily how much functionality they can use from your caQtDM. I did one before as below:
Graphics
Graphics
Graphics
Description
MEDM widget (from Doc)
CaQtDM
Line
Lines
caPolyLine
Rectangle
Rectangle
caGraphics
Oval
Circle
caGraphics
Arc
Arc
caGraphics
Text
Static Text
caLabel
caImage
GIF Image
PNG Image
HTML
Dynamic Symbols
Polygon
caPolyLine
Polyline
caPolyLine
Monitors
Monitors
Graphics
CaQtDM
Meter Monitor
Meter
caThermo
Bar
Bar
caThermo
Text
Text Monitor
caLineEdit
Byte Monitor
caByte
Byte
Cartesian Plot
caCartesianPlot
Strip Chart
caStripPlot
X-Y Graph
caCartesianPlot
or caStripPlot
Message Box
Symbols
Scale Monitor
Controls
Controls
Graphics
Description
CaQtDM
Entry Text
Text
caTextEntry
Slider
Slider
caSlider
Menu
Menu Button
caMenu
Choice Button
Choice Button
caChoice
Message Button
Message Button
caMessageButton
Related Display
Related Display
caRelatedDisplay
Shell Command
Shell Command
caShellCommand
Menu Mux (multiplexor)
Multiplexor
Button
Motif Slider
caSlider
Up/Down Button
Exit Button
Radio Box
Wheel Switch
caNumeric
Composite
Use caFrame and caInclude
Display
Hope that helps
Best regards
Zai Wang
Subject:
caQtDM
"Mezger Anton Christian (PSI)" <[email protected]>
To:
"'[email protected]'" <[email protected]>, "'[email protected]'" <[email protected]>
Date:
Tue, 27 Jan 2015 09:08:14 +0000
Dear all,
Version 3.8.9 of caQtDM is available for linux, windows, macOS and IOS (Ipad). The IOS version 3.8.9 can be downloaded from the apple store (new version in about one week).
Now this version also includes a simple tool called edl2ui to convert edm files to ui files. caQtDM follows the philosophy of MEDM and thus not all features of EDM can be integrated. edl2ui is therefore a simplified conversion tool and while at PSI EDM is not used, it could not be really fully tested. However it is quite easy to modify and add forgotten items and properties (see parserClass.cc in directory parserEDM). This could be done by the interested laboratories. Please return then to us the changes made.
Give me some feedback if you are using caQtDM.
Best regards
Anton Mezger
Paul Scherrer Institut
Switzerland
Prev: Re: Problem in building EPICS Rahul Jain
Next: Problems with CA Florian Feldbauer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: caQtDM Mark S. Engbretson
Next: Re: Problem in building EPICS Johnson, Andrew N.
