1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem in building EPICS
To: Rahul Jain <[email protected]>
Cc: EPICS mailing list <[email protected]>
Date: Wed, 28 Jan 2015 06:15:17 +0000
What happens if you just run 'make' without the 'sudo' (which you should not be using, Base does not need to be built as root)?
Are you building an old version of Base for any specific reason? The latest version is 3.14.12.4 and contains various advances and bug fixes since 3.14.11. The Channel Access network protocol is compatible across different versions.
- Andrew
Sent from my iPad
> On Jan 27, 2015, at 11:26 PM, Rahul Jain <[email protected]> wrote:
> Hello
> I am trying to build EPICS base 3.14.11 on linux-x86 (32 bit) but when I
> run sudo make command, I get following error:
> confiugure/CONFIG:55: configure/os/CONFIG.unsupported.Common: No such file
> or directory
> *** No rule to make target 'configure/os/ CONFIG.unsupported.Common'.    Stop
> I have used following configuration set up for crosscompiling EPICS
> Set up of configure/CONFIG_SITE script
> CROSS_COMPILER_TARGET_ARCHS=linux-arm
> CROSS_COMPILER_HOST_ARCHS=linux-x86
> SHARED_LIBRARIES=NO
> STATIC_BUILD=YES
> Our cross-compiling toolchain is in $HOME/local/x-tools/arm-unknown-linux
> gnueabi, so I used following configuration:-
> Set up of configure/os/CONFIG_SITE.linux-x86.linux-arm
> GNU_DIR = $HOME/local/x-tools/arm-unknown-linux gnueabi
> GNU_TARGET = arm-unknown-linux gnueabi
> I have also tried setting up EPICS_HOST_ARCH environment variable
> seperately by using following command:
> export EPICS_HOST_ARCH=linux-x86
> I am still getting same error message, Please solve my above query.
> Thanks
> Rahul Jain
Re: Problem in building EPICS Rahul Jain
Prev: RE: caQtDM Mark S. Engbretson
Next: Issues with installing the adPython plugin for areaDetector David Michel
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: caQtDM Zai Wang
Next: Re: Problem in building EPICS Rahul Jain
