Hi Ralph,
I would like recommend you to test APC 7921 for your purpose. It
supports SNMPv1/v2c/v3 and serial connection.
* EPICS
You can use FRIB's 3rd generation EPICS driver in order to control
them via EPICS. We tested them, and it works well so far. However, FRIB
SNMP doesn't match what actually we want, so we are developing our own
EPICS support. Of course, you can directly use the SNMP command.
* controllable using a decent interface (prefer ASCII over web server)
It has the Ethernet and Serial interfaces. Several years ago, I did
several time serial connection through serial server (digi portserver)
with a homemade serial cable between APC7921 and digi portserver. It
saved my time when the cheap network switch was dead during data taking,
because the digi portserver used a dedicated Ethernet connection instead
of a network switch. So, technically, asyn can do this if you want to
integrate them into EPICS if you prefer a serial connection over web
server (serial server)
* small and affordable (rather 5 than 20 outlets).
1U, 8 outlets, and rack mountable.
* radiation hardened
I don't know much about any quantitative results. But I can say, I
used several APC units (some old, some APC7921) in the experimental hall
while I was working at Jefferson Lab. The devices which I managed were
located in a dog-house (a concreted bunker). And a device (a bit APC old
model) was located in the backward position of the liquid hydrogen
target. This old model was used in that hall long ago before I was
there. And it didn't response several times during my duty (2 years).
* magnetic field hardened.
I have no idea about this.
Han
Dear All,
We are looking for remote controllable power strips, to be mounted in
19" racks (full size and small units).
It would be great if they'd be
Any ideas or pointers?
Thanks a lot!
~Ralph
Jeong Han Lee, Dr.rer.nat.
Accelerator Systems Division
Rare Isotope Science Project
Institute for Basic Science
Daejeon, South Korea
tel : +82-42-878-8733
fax : +82-42-878-8799
- Remote Controlled Power Distribution Units? Ralph Lange
Re: Strawberry Perl Make still broken? Johnson, Andrew N.
Re: Strawberry Perl Make still broken? Benjamin Franksen
<2015>
2025
2026
Re: Remote Controlled Power Distribution Units? Maren Purves
synApps caputRecorder module Mooney, Tim M.
<2015>
2025
2026
