Am Montag, 2. Februar 2015, 17:45:19 schrieb J. Lewis Muir:
> Is the GNU Make that comes with Strawberry Perl still broken?
> I tried building EPICS Base 3.14.12.4, with the Known Problems patches
> applied, on Windows 7 for win32-x86 using the "gmake" included with
> Strawberry Perl 5.20.1.1, and it succeeded. The "gmake" program
> identified its version as "4.0.90" on the command line when executed
> with the "--version" option. According to
> http://www.aps.anl.gov/epics/base/win32.php
> the GNU Make that comes with Strawberry Perl is broken.
Note the page says: "Strawberry Perl comes with GCC, but its GNU Make does not
provide some features needed by the EPICS build system"
That does not mean Strawberry Perl's make is or was "broken". EPICS relies on
lots of extensions that are only available recent versions of gnumake. It
needs at least 3.81, but I am not sure 3.82 is suitable, see the multiple
"WARNING: Backward-incompatibility" on:
https://lists.gnu.org/archive/html/info-gnu/2010-07/msg00023.html
> Is this still
> true, or does the fact that I was able to build EPICS Base successfully
> suggest that perhaps the problem has been fixed?
I guess so, perhaps they fixed those incompatibilities in 4.x. Unfortunately
4.0.90 is not an official release of gnu make (see
http://ftp.gnu.org/gnu/make/). To be sure I would recommend trying to build
3.15 against this version of make and report back if there are problems. You
could also try to build synApps. If that runs through w/o errors you should be
pretty safe.
Cheers
Ben
"Make it so they have to reboot after every typo." -- Scott Adams
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
- Strawberry Perl Make still broken? J. Lewis Muir
Re: Remote Controlled Power Distribution Units? Jeong Han Lee
RE: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter Mark S. Engbretson
<2015>
2025
2026
Re: Strawberry Perl Make still broken? Johnson, Andrew N.
Problem about cross-complie SynApps 吴洪金
<2015>
2025
2026
