1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Problem about cross-complie SynApps
To: [email protected]
Date: Thu, 5 Feb 2015 10:23:25 +0800 (GMT+08:00)
Hi, I am trying to cross-compile SynApps_5_6 on CentOS6.6 (32bit and runing in VMware),I have successfully finished cross-compling the base-3.14.12 on that CentOS6.6 . I have installed the: msi , re2c packages. It seems like that the problem is from cross-compling the "areaDetector-1-8beta1" App , because the I getting the following error :
/include      -I/home/wuhj/epics/Tornado2.2/target/h ../BISDetector.cpp
../BISDetector.cpp: In method `enum asynStatus BISDetector::readSFRM(const char *, epicsTimeStamp *, double, NDArray *)':
../BISDetector.cpp:153: passing `const char *' as argument 1 of `stat(char *, stat *)' discards qualifiers
make[3]: *** [BISDetector.o] Error 1
make[3]: Leaving directory `/home/wuhj/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/brukerSrc/O.vxWorks-ppc604_long'
make[2]: *** [install.vxWorks-ppc604_l ong] Error 2
make[2]: Leaving directory `/home/wuhj/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp/brukerSrc'
make[1]: *** [brukerSrc.install] Error 2
make[1]: Leaving directory `/home/wuhj/epics/synApps_5_6/support/areaDetector-1-8beta1/ADApp'
make: *** [ADApp.install] Error 2
If I comment the areaDetector module in the file :$(support)/configure/RELEASE , then the whole SynApps will be successfully cross-compiled without errors .
I am new to EPICS and thanks a lot for the help .
RE: Problem about cross-complie SynApps Mark Rivers
Prev: Re: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter Jani Hakala
Next: RE: Problem about cross-complie SynApps Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Strawberry Perl Make still broken? Benjamin Franksen
