1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter
To: EPICS Tech-Talk <[email protected]>
Date: Tue, 03 Feb 2015 04:45:13 +0200
"J. Lewis Muir" <[email protected]> writes:
> Obviously, it seems to be unhappy with the "delete" on line 93 of
> epicsRingPointer.h, but I don't know how to fix it.  Here's a
> Microsoft reference for compiler error C2664 for Visual Studio 2013
> (not the compiler used) in case it helps:
My guess is that the compiler doesn't like the volatile data members in
the class.
> Any ideas?
The class could be perhaps implemented using a mutex for locking if the
code in epicsRingPointer class needs to be thread-safe.
The uses of epicsRingPointerCreate, epicsRingPointerPush,
epicsRingPointerPop, etc. seem to be coupled with some locking. Perhaps
those volatile type qualifiers could be removed from epicsRingPointer
class.
In any case, page
    http://en.wikipedia.org/wiki/Volatile_%28computer_programming%29
says that
 "C++11
  According to the C++11 ISO Standard, the volatile keyword is only meant
  for use for hardware access; do not use it for inter-thread
  communication. For inter-thread communication, the standard library
  provides std::atomic<T> templates."
Jani Hakala
epicsRingPointer.h error C2664: 'delete' : cannot convert parameter J. Lewis Muir
Prev: RE: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter Mark S. Engbretson
Next: Problem about cross-complie SynApps 吴洪金
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter J. Lewis Muir
Next: related to coding priya tiwari
