1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fetching return value from external program call in StreamDevice
To: "Mooney, Tim M." <[email protected]>
Date: Thu, 5 Feb 2015 18:09:30 +0000
Hi:
Yes, for getting data from python into EPICS, using Channel Access it definitely a worthwhile approach.
You can add CA server to python so that it serves the data right away,
or add a CA client to python which writes the data to records in a "real" IOC as Tim explains.
The CA client approach is less code, especially if you already have an IOC.
An advantage of the CA server approach:
When using cainfo to see where the PV is coming from, you can (with a few intermediate steps) identify the python process.
If the python process crashes, you'll know, because the PV is gone.
With the python-client-writes-to-IOC approach, the python code is a layer removed.
If the python client crashes, your PV simply won't update, and you might notice that too late.
Rod's suggestion to turn the python script into a simple TCP server, then read that via stream device can be in-between:
Not too much code, and stream device will tell you right away about read errors when the python process dies.
-Kay
On Feb 5, 2015, at 12:56 PM, "Mooney, Tim M." <[email protected]>
 wrote:
> I just wrote some python code...write the sensor value to an EPICS PV
Fetching return value from external program call in StreamDevice Christian Pauly
RE: Fetching return value from external program call in StreamDevice Mooney, Tim M.
Prev: Re: Fetching return value from external program call in StreamDevice Rod Nussbaumer
Next: RE: Fetching return value from external program call in StreamDevice Al Honey
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Fetching return value from external program call in StreamDevice Mooney, Tim M.
Next: Re: Fetching return value from external program call in StreamDevice Dirk Zimoch
