1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Fetching return value from external program call in StreamDevice
To: <[email protected]>
Date: Fri, 6 Feb 2015 14:51:14 +0100
Hi Christian
At the moment, StreamDevice cannot do this directly. The 'exec' command can only pass parameters to an external program but cannot pipe data into the program or read its output, nor can it evaluate the exit status.
But it would be a nice exercise to write an asynOctet driver that uses a piped program instead of a serial line.
drvAsynPipeConfigure "myProgramPort" "program arg1 arg2 arg3 ..."
The driver may restart the program whenever it has exited and asyn tries to talk to the port again (i.e. autoConnect).
Any volunteers?
Dirk
On 05.02.2015 17:58, Christian Pauly wrote:
Hi
I want to read out a little pressure sensor, for which i have already a
small python script which reads the sensor (via i2c bus) and prints the
sensor value to the terminal. Alternatively, i could also give the
sensor value as return value upon program exit.
Now i want to read this sensor inside an EPICS IOC.
Is it possible, to use StreamDevice for this, by calling the external
script / program and evaluating the return value ?
Maybe using the "exec" statement in the protocol file ?
Reading the sensor takes some time (500ms), so it would be good to do it
asynchronously, without blocking the IOC.
Or is there any other easy way, without reimplementing all the i2c
sensor readout eg inside an ASYN driver in C++ code ?
Thanks for any hints or help
Best regards,
Christian
Re: Fetching return value from external program call in StreamDevice Torsten Bögershausen
Re: Fetching return value from external program call in StreamDevice Phillip Sorensen
Fetching return value from external program call in StreamDevice Christian Pauly
Prev: Re: Issues with installing the adPython plugin for areaDetector David Michel
Next: V4 pvDatabase PVRecord bug? Bruno Martins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fetching return value from external program call in StreamDevice Kasemir, Kay
Next: Re: Fetching return value from external program call in StreamDevice Torsten Bögershausen
