1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: V4 pvDatabase PVRecord bug?
Date: Fri, 6 Feb 2015 15:04:58 -0500
Hi everyone,
I am doing some experiments with v4. I have a simple v4 IOC with a single NTNDArray record. On the client side I'm just monitoring it with pvget -m.
Everything works fine as I put new values on different fields of my record, except for the 'value' field, which is a union. If I put a new value there (select, reuse, copy data, replace) the monitor doesn't pick up the change. Other fields update automatically after put(). I can fix this by calling the method postPut on the field.
Is this the way it's supposed to be?
I'm using the latest version of everything from the mercurial repos.
Thanks!
Bruno
Re: V4 pvDatabase PVRecord bug? Tom Slejko
Prev: Re: Fetching return value from external program call in StreamDevice Dirk Zimoch
Next: epics on ios Mezger Anton Christian (PSI)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Fetching return value from external program call in StreamDevice Christian Pauly
Next: Re: V4 pvDatabase PVRecord bug? Tom Slejko
