1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: using EPICS code with HTTP port
To: "'Ana Malagon'" <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 9 Feb 2015 20:02:31 +0000
This command should be:
drvAsynIPPortConfigure("L0","10.95.101.75:80 HTTP",0,0,0)
The HTTP means that drvAsynIPPort will handle the fact that the server will disconnect after each transaction.
You can’t use the “curl” command in your protocol.  You need to send the actual commands that the HTTP server requires.
It might be something like
getData {
    out "get data";
    in "%\$1[^\r\n]";
    ExtraInput = Ignore;
From: [email protected] [mailto:[email protected]] On Behalf Of Ana Malagon
Sent: Monday, February 09, 2015 1:53 PM
To: [email protected]
Subject: using EPICS code with HTTP port
I'm trying to use EPICs with a digitizer (www.redpitaya.com) which has a web interface - I can get the information using curl to download the website information:
but I'm a little confused about how to integrate these commands in an ioc. I've set up a StreamDevice template, and I thought I might be able to just send the curl commands by putting them in a record:
record(bo, "$(P)$(R)Start")
    field(DESC, "Start App")
    field(DTYP, "stream")
    field(OUT, "@devREDPITAYASTREAM.proto startApp $(PORT) $(A)")
    field(ZNAM, "spectrum")
    #field(PINI, "YES")
    #field(VAL, "1")
record(waveform, "$(P)$(R)Data")
    field(DESC, "Data string")
    field(INP,  "@devREDPITAYASTREAM.proto getData(20000) $(PORT) $(A)")
    field(PINI, "YES")
    field(FTVL, "CHAR")
    field(NELM, "32000")
with the corresponding entries in the .proto file being:
startApp {
    out "curl http://10.95.101.75/bazaar?start=%{spectrum}";
getData {
    out "curl http://10.95.101.75/data";
    in "%\$1[^\r\n]";
When I run st.cmd, the host is configured to be the IP address of the red pitaya itself, using the HTTP port of 80:
drvAsynIPPortConfigure("L0","10.95.101.75:80",0,0,0)
I'm not sure if this is the right thing to do? In any case, when running st.cmd with asynTraceMask enabled I get a continuous stream of "reads"
2015/02/09 11:48:23.530 10.95.101.75:80 read.
but it doesn't seem to respond to the commands I've made.
Does anyone have any feeling for using Epics with HTTP commands?
Thanks!
Ana Malagon
Re: using EPICS code with HTTP port Kasemir, Kay
using EPICS code with HTTP port Ana Malagon
Prev: using EPICS code with HTTP port Ana Malagon
Next: Re: using EPICS code with HTTP port Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
