1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: CA Repeater: bind test err was "The operation completed successfully. "
To: <[email protected]>, <[email protected]>, <[email protected]>
Date: Tue, 10 Feb 2015 16:54:14 +0000
Hi Andrew,
I was referring to the epicsSocketDestroy() in makeSocket() rather than the one in verify(). I've checked on a windows machine and I can reproduce Lewis' behaviour - if I add a print of SOCKERRNO after a failed bind() in makeSocket() I see an error code of 10048, but printing it out again after the call to epicsSocketDestroy () in makeSocket() gives 0
Freddie
> -----Original Message-----
> From: Johnson, Andrew N. [mailto:[email protected]]
> Sent: 10 February 2015 16:29
> To: Akeroyd, Freddie (STFC,RAL,ISIS)
> Cc: [email protected]; [email protected]
> Subject: Re: CA Repeater: bind test err was "The operation completed
> successfully. "
> Hi Freddie,
> The condition test in the verify() method either calls epicsSocketDestroy() or
> it examines the SOCKERRNO value, so I don't think your explanation quite
> works. I can't explain what's going on with Lewis' machine right now, but I'm
> not a Windows networking expert at all. Anybody else got any ideas?
> - Andrew
> On Feb 10, 2015, at 4:29 AM, [email protected] wrote:
> > Hi Lewis,
> > I think the bind() in makeSocket() is failing (as expected) but the
> subsequent successful call to epicsSocketDestroy() in the same function is
> clearing the error code, hence when the check is made in
> repeaterClient::verify () rather than SOCK_EADDRINUSE it is finding 0.  One
> way to fix it might be to change makeSocket() to make a copy of any socket
> error code and then return that (or 0 on success) rather than true/false
> > Regards,
> > Freddie
> >> From: [email protected] [mailto:tech-talk-
> >> [email protected]] On Behalf Of J. Lewis Muir
> >> Sent: 09 February 2015 22:13
> >> To: EPICS Tech-Talk
> >> Subject: CA Repeater: bind test err was "The operation completed
> >> successfully. "
> >> Hello.
> >> When I run caRepeater.exe from a command prompt in Windows 7 and
> then
> >> run camonitor.exe in another command prompt for a PV (hosted on an
> IOC
> >> on a different machine) of type DBF_LONG that is updating at about 10
> >> Hz, the caRepeater.exe process prints the following message on the
> >> console:
> >> The camonitor.exe program seems to continue to run correctly.
> >> Does anyone know how to fix this?
> >> I looked briefly at src/ca/repeater.cpp where this error is printed,
> >> and I changed the fprintf call to also print SOCKERRNO using the format
> >> "%d", and it prints 0.
> >> This is using win32-x86 EPICS Base 3.14.12.4 (with the Known Problems
> >> patches applied) on Windows 7.
> >> Thank you!
> >> Lewis
Re: CA Repeater: bind test err was "The operation completed successfully. " Andrew Johnson
CA Repeater: bind test err was "The operation completed successfully. " J. Lewis Muir
RE: CA Repeater: bind test err was "The operation completed successfully. " freddie.akeroyd
Re: CA Repeater: bind test err was "The operation completed successfully. " Johnson, Andrew N.
Prev: Re: CA Repeater: bind test err was "The operation completed successfully. " Johnson, Andrew N.
Next: Re: medm3.1.8 linker problem Bob Soliday
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: CA Repeater: bind test err was "The operation completed successfully. " Andrew Johnson
