Subject: |
CA Repeater: bind test err was "The operation completed successfully. " |
"J. Lewis Muir" <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Mon, 09 Feb 2015 16:12:35 -0600 |
Hello.
When I run caRepeater.exe from a command prompt in Windows 7 and then
run camonitor.exe in another command prompt for a PV (hosted on an IOC
on a different machine) of type DBF_LONG that is updating at about 10
Hz, the caRepeater.exe process prints the following message on the
console:
The camonitor.exe program seems to continue to run correctly.
Does anyone know how to fix this?
I looked briefly at src/ca/repeater.cpp where this error is printed,
and I changed the fprintf call to also print SOCKERRNO using the format
"%d", and it prints 0.
This is using win32-x86 EPICS Base 3.14.12.4 (with the Known Problems
patches applied) on Windows 7.
Thank you!
Lewis
- RE: CA Repeater: bind test err was "The operation completed successfully. " freddie.akeroyd
Re: using EPICS code with HTTP port Kasemir, Kay
Re: epicsRingPointer.h error C2664: 'delete' : cannot convert parameter J. Lewis Muir
<2015>
2025
2026
Re: using EPICS code with HTTP port Jack
<2015>
2025
2026
