1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using EPICS code with HTTP port
To: [email protected]
Date: Wed, 11 Feb 2015 11:45:53 -0600
On Wed, Feb 11, 2015 at 02:28:39PM +0100, Dirk Zimoch wrote:
> On 09.02.2015 21:58, Kasemir, Kay wrote:
>> and then you need to be prepared to parse a response that looks like
>> HTTP/1.1 200 OK
>> Content-Type: text/html
>> Server: Whatever
>> Cache-Control: no-cache
>> Pragma: no-cache
>> Content-Length: 97
>> .. the actual data..
> Try regular expressions to fund the actual data in all the http noise.
> See my example in the StreamDevice documentation:
> http://epics.web.psi.ch/software/streamdevice/doc/tipsandtricks.html#web
> get_title {
>   extrainput = ignore;
>   replyTimeout = 1000;
>   out "GET http://\$1\n\n";;
>   in "%+.1/(?im)<title>(.*)<\/title>/";
Something like this can work with a device that always responds in a fixed
pattern.  However, you should be aware that, in general, regular expressions
cannot be used to parse arbitrary HTML.  A Stack Overflow article that
talks about this can be found here:
    http://stackoverflow.com/questions/6751105/why-its-not-possible-to-use-regex-to-parse-html-xml-a-formal-explanation-in-la
A more entertaining, though less illuminating, explanation can be found here:
    http://stackoverflow.com/questions/1732348/regex-match-open-tags-except-xhtml-self-contained-tags/1732454#1732454
Hope this helps.
Bill Lavender
Re: using EPICS code with HTTP port Dirk Zimoch
using EPICS code with HTTP port Ana Malagon
RE: using EPICS code with HTTP port Mark Rivers
Re: using EPICS code with HTTP port Kasemir, Kay
Prev: Re: Multiple IOCs on single non-networked host Re: can run multiple IOCs on single host? J. Lewis Muir
Next: EPICS Collaboration Meeting May 2014 Hoff, Larry
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: using EPICS code with HTTP port Dirk Zimoch
Next: Re: using EPICS code with HTTP port Dirk Zimoch
