1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device)
To: Andrew Gomella <[email protected]>, "[email protected] Talk" <[email protected]>
Date: Thu, 12 Feb 2015 03:05:21 +0000
Hi Andrew,
I recently taught a class on asyn where we did a hands-on exercise writing a driver that communicates with a Newport XPS using the drvAsynIPPort as the underlying transport.
The handout is here:
http://www.aps.anl.gov/epics/docs/APS2015/10-AsynDriver-Lab.pdf
A tar file with the example driver fully worked out, and a template driver as an exercise for the students can be found here:
http://cars.uchicago.edu/gsecars/data/epics/XPSExample.tgz
The lecture slides and YouTube videos of the classes are here:
http://www.aps.anl.gov/epics/docs/APS2015.php
Let me know if you have questions.
From: [email protected] [[email protected]] on behalf of Andrew Gomella [[email protected]]
Sent: Wednesday, February 11, 2015 7:52 PM
To: [email protected] Talk
Subject: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device)
I tried searching the on the APS list of hardware here (http://www.aps.anl.gov/epics/modules/bus.php#RS%2d232%20%28Asyn%29) but I am having trouble finding an application that fits the above description.
I would like to use it as a template to write support for a tricky device I am working with (which works with stream device 95% of the time but produces some occasional problems due to unpredictable ordering of output messages as well as grouping unsolicited messages with solicited output).
If anyone could  point an example application that does not use stream device that would be great.
Andrew
Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device) Andrew Gomella
Prev: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device) Andrew Gomella
Next: Re: EPICS Collaboration Meeting May 2014 Torsten Bögershausen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device) Andrew Gomella
