1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Using the EPICS Build/Make system to build kernel modules for linux
From: "Williams Jr., Ernest L." <[email protected]>
Date: Fri, 13 Feb 2015 00:20:54 +0000
Hi everyone,
As I begin this task; maybe someone else has already done it :)
We typically have kernel module source from hardware vendors that we recompile for our target architectures
In my case, I have the following architectures:
(1) linux-x86                         (RHEL6 32-bit)
(2) linux-x86_64                 (RHEL6  64-bit)
(3) linuxRT-x86                    (32-bit linux w/realtime patch and ucLibc)
(4) linuxRT-x86_64            (64-bit linux w/realtime patch and ucLibc)
(5) linuxRT_glibc-x86_64  (64-bit linux w/realtime patch and gLibc)
I would like to hi-jack the EPICS Make system framework to build kernel modules.
I already use the EPICS Make system to build non-EPICS linux userspace libraries:  Works great. :)
Has anyone, used the EPICS Make system to build kernel modules?
Maybe, some EPICS  "RULES" for building kernel modules?
Cheers,
Ernest
Re: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
Prev: Re: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device) Andrew Gomella
Next: RE: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device) Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Example asyn device support for rs-232 hardware with unsolicited messages (without using stream-device) Mark Rivers
Next: Re: Using the EPICS Build/Make system to build kernel modules for linux Jameson Graef Rollins
