1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Error in EDM-1-12-98 installation
To: [email protected]
Date: Wed, 18 Feb 2015 09:45:05 +0530
Hello,
I am facing problem in installing edm-1-12-98, although I have already
installed the following libraries required for EDM installation on my
linux-x86 (ubuntu 14.04) PC.
libx11-dev, libxtst-dev, zlib1g-dev giflib-4.1.3,  libungif-4.1.3,
libpng-1.2.6rc1-config, libxt-dev, libmotif-dev, x11proto-print-dev,
libxmu-headers, libxp-dev, libxmu-dev, libxmu6
The error messages, while installing edm-1-12-98 is given as follows:-
/usr/bin/g++ -o edm  -L/opt/myepics/base-3.14.12.4/lib/linux-x86
-L/opt/myepics/extensions/lib/linux-x86 -L/usr/lib
-L/usr/lib/i386-linux-gnu
-Wl,-rpath,/opt/myepics/base-3.14.12.4/lib/linux-x86
-Wl,-rpath,/opt/myepics/extensions/lib/linux-x86 -Wl,-rpath,/usr/lib
-Wl,-rpath,/usr/lib/i386-linux-gnu       -m32  -z combreloc -z lazyload
         main.o    -lcfcaa62e-8199-11d3-a77f-00104b8742df
-l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXmu -lXt -lXp -lXtst -lX11
-lca -lCom  -lpthread -ldl
/usr/bin/ld: warning: -z lazyload ignored.
/usr/lib/libXm.so: undefined reference to `png_read_info@PNG12_0'
/usr/lib/i386-linux-gnu/libfreetype.so.6: undefined reference to
`png_set_filler@PNG12_0'
`png_set_packing@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_sig_bytes@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_read_update_info@PNG12_0'
`png_set_interlace_handling@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_create_read_struct@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_rowbytes@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_read_image@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_gray_to_rgb@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_IHDR@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_channels@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_strip_16@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_expand@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_init_io@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_gAMA@PNG12_0'
`png_get_io_ptr@PNG12_0'
`png_set_palette_to_rgb@PNG12_0'
`png_get_error_ptr@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_gamma@PNG12_0'
`png_destroy_read_struct@PNG12_0' /usr/lib/libXm.so: undefined reference
to `png_read_end@PNG12_0'
`png_error@PNG12_0'
`png_set_read_user_transform_fn@PNG12_0'
`png_set_read_fn@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_create_info_struct@PNG12_0'
`png_set_expand_gray_1_2_4_to_8@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_sig_cmp@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_valid@PNG12_0'
`png_set_tRNS_to_alpha@PNG12_0'
collect2: error: ld returned 1 exit status
make[2]: *** [edm] Error 1
make[2]: Leaving directory
`/opt/myepics/extensions/src/edm/edmMain/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/myepics/extensions/src/edm/edmMain' make:
*** [edmMain.install] Error 2
Please suggest me, how to fix this error message.
Regards
Rahul Jain
RE: Error in EDM-1-12-98 installation Mark Rivers
Re: Error in EDM-1-12-98 installation Mike Westfall
Prev: RE: Possible to set EOS in asyn to match a character plus whatever character follows? Mark Rivers
Next: RE: Error in EDM-1-12-98 installation Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
