1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Error in EDM-1-12-98 installation
To: Rahul Jain <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 18 Feb 2015 04:19:43 +0000
I think you need the package called libpng12-0
From: [email protected] [[email protected]] on behalf of Rahul Jain [[email protected]]
Sent: Tuesday, February 17, 2015 10:15 PM
To: [email protected]
Subject: Error in EDM-1-12-98 installation
Hello,
I am facing problem in installing edm-1-12-98, although I have already
installed the following libraries required for EDM installation on my
linux-x86 (ubuntu 14.04) PC.
libx11-dev, libxtst-dev, zlib1g-dev giflib-4.1.3,  libungif-4.1.3,
libpng-1.2.6rc1-config, libxt-dev, libmotif-dev, x11proto-print-dev,
libxmu-headers, libxp-dev, libxmu-dev, libxmu6
The error messages, while installing edm-1-12-98 is given as follows:-
/usr/bin/g++ -o edm  -L/opt/myepics/base-3.14.12.4/lib/linux-x86
-L/opt/myepics/extensions/lib/linux-x86 -L/usr/lib
-L/usr/lib/i386-linux-gnu
-Wl,-rpath,/opt/myepics/base-3.14.12.4/lib/linux-x86
-Wl,-rpath,/opt/myepics/extensions/lib/linux-x86 -Wl,-rpath,/usr/lib
-Wl,-rpath,/usr/lib/i386-linux-gnu       -m32  -z combreloc -z lazyload
         main.o    -lcfcaa62e-8199-11d3-a77f-00104b8742df
-l114135a4-6f6c-11d3-95bc-00104b8742df -lXm -lXmu -lXt -lXp -lXtst -lX11
-lca -lCom  -lpthread -ldl
/usr/bin/ld: warning: -z lazyload ignored.
/usr/lib/libXm.so: undefined reference to `png_read_info@PNG12_0'
/usr/lib/i386-linux-gnu/libfreetype.so.6: undefined reference to
`png_set_filler@PNG12_0'
`png_set_packing@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_sig_bytes@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_read_update_info@PNG12_0'
`png_set_interlace_handling@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_create_read_struct@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_rowbytes@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_read_image@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_gray_to_rgb@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_IHDR@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_channels@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_strip_16@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_expand@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_init_io@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_gAMA@PNG12_0'
`png_get_io_ptr@PNG12_0'
`png_set_palette_to_rgb@PNG12_0'
`png_get_error_ptr@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_set_gamma@PNG12_0'
`png_destroy_read_struct@PNG12_0' /usr/lib/libXm.so: undefined reference
to `png_read_end@PNG12_0'
`png_error@PNG12_0'
`png_set_read_user_transform_fn@PNG12_0'
`png_set_read_fn@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_create_info_struct@PNG12_0'
`png_set_expand_gray_1_2_4_to_8@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_sig_cmp@PNG12_0'
/usr/lib/libXm.so: undefined reference to `png_get_valid@PNG12_0'
`png_set_tRNS_to_alpha@PNG12_0'
collect2: error: ld returned 1 exit status
make[2]: *** [edm] Error 1
make[2]: Leaving directory
`/opt/myepics/extensions/src/edm/edmMain/O.linux-x86'
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/myepics/extensions/src/edm/edmMain' make:
*** [edmMain.install] Error 2
Please suggest me, how to fix this error message.
Regards
Rahul Jain
Error in EDM-1-12-98 installation Rahul Jain
Prev: Error in EDM-1-12-98 installation Rahul Jain
Next: Re: Error in EDM-1-12-98 installation Mike Westfall
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
