Hello tech-talkers, I am running into the following error when I try to compile the following area detector module. https://github.com/areaDetector?page=2 make -C ./nexusSrc install make[3]: Entering directory `C:/Epics/support/areaDetector-2-0/ADCore/ADApp/nexu sSrc' make -C O.windows-x64 -f ../Makefile TOP=../../.. T_A=windows-x64 install make[4]: Entering directory `C:/Epics/support/areaDetector-2-0/ADCore/ADApp/nexu sSrc/O.windows-x64' link /nologo /subsystem:windows /dll /LTCG /incremental:no /opt:ref /release / MACHINE:X64 /implib:NeXus.lib /out:NeXus.dll napi.obj napi5.obj nap iu.obj nxdataset.obj nxio.obj nxstack.obj nxxml.obj stptok.obj C:\Epics\sup port\areaDetector-2-0\\ADBinaries\\lib\\windows-x64\\hdf5.lib C:\Epics\support\ areaDetector-2-0\\ADBinaries\\lib\\windows-x64\\szip.lib C:\Epics\support\areaD etector-2-0\\ADBinaries\\lib\\windows-x64\\zlib.lib napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SHORT_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT32_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT8_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT64_g napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_DATASET_CREATE_ID_ g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_USHORT_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UCHAR_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_SCHAR_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_FLOAT_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT8_g napi5.obj : error LNK2001: unresolved external symbol H5T_C_S1_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT16_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT16_g napi5.obj : error LNK2001: unresolved external symbol H5P_CLS_FILE_ACCESS_ID_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_UINT32_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_INT64_g napi5.obj : error LNK2001: unresolved external symbol H5T_NATIVE_DOUBLE_g NeXus.dll : fatal error LNK1120: 19 unresolved externals make[4]: *** [NeXus.dll] Error 1120 make[4]: Leaving directory `C:/Epics/support/areaDetector-2-0/ADCore/ADApp/nexus Src/O.windows-x64' make[3]: *** [install.windows-x64] Error 2 make[3]: Leaving directory `C:/Epics/support/areaDetector-2-0/ADCore/ADApp/nexus Src' make[2]: *** [nexusSrc.install] Error 2 make[2]: Leaving directory `C:/Epics/support/areaDetector-2-0/ADCore/ADApp' make[1]: *** [ADApp.install] Error 2 make[1]: Leaving directory `C:/Epics/support/areaDetector-2-0/ADCore' make: *** [ADCore.install] Error 2 My build site is configured as follows: Epics base-3.14.12.4 (compiled dynamically) using MS Visual studio 12.0 all required support libraries for area detector are compiled namely: ASYN=$(SUPPORT)/asyn-4-26 AUTOSAVE=$(SUPPORT)/autosave-5-5 BUSY=$(SUPPORT)/busy-1-6 SSCAN=$(SUPPORT)/sscan-2-10 CALC=$(SUPPORT)/calc-3-4-2 and EPICS host env variable is set to windows-x64 I know previously, dynamic build for area detector wasn't possible for modules before 1-9-1. I am using 2-0 (I am guessing that is the one currently hosted at github. I searched for this issue on tech-talks and found that the error has something to do with the HDF5 library. I wanted to know if someone can help me fix this. Any help is appreciated. Thank you. Best, Ali -- Alireza Panna University of Maryland, College Park
| ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
