Hello Ana,
StreamDevice is not a *generic* parser for JSON (or XML or other generic
formats). It expects that the same request always sends a reply in the
same format. In particular it expects the same data in the same order.
Generally, JSON may send values in any order or send a different set of
values with each call. But often it behaves much more harmless than it
could. So if the format of your JSON reply is always the same,
StreamDevice may still work. Just parse one value after the other and
use redirects, i.e. %(other_record)...
But even if the reply is not always in the same order, not all hope is
lost. You can set up several records with SCAN="I/O Intr". They will all
get a copy of the input. Each can parse the input for its own value and
ignore the rest. Note that this is less efficient than redirects because
the input needs to be copied for each record.
To help you more, I need some example data.
Dirk
On 20.02.2015 18:40, Ana Malagon wrote:
Hi all,
Thanks very much! Dirk, thanks for the tip about using regular
expressions - I am trying that now and hopefully can get it to work.
I realized however that if I wanted to include the functionality of a
json parser, such as https://github.com/json-c/json-c, that I would have
no idea where to start with the StreamDevice template, as it only has
the db and protocol file.
I think I could do this with the old devGpib template, as the commands
are defined in a C file, but does anyone know how I might get a JSON
parser to work with StreamDevice?
Ana
On Wed, Feb 18, 2015 at 4:37 PM, Mark Rivers <[email protected]
<mailto:[email protected]>> wrote:
Hi Ana,____
__ __
I notice you have set the NELM field of the waveform record to
32000. That is larger than the default value of
EPICS_CA_MAX_ARRAY_BYTES, which is 16K. You need to set the value
of the environment variable EPICS_CA_MAX_ARRAY_BYTES to a value
larger than 32000 on both the IOC process and any EPICS channel
access client process.____
__ __
If that does not fix your problem then I would suggest the
following:____
__ __
- Create the drvAsynIPPort driver____
- Open an asyn record to the driver____
- Use the medm asynRecord.adl and asynOctet.adl screens____
- Turn on ASYN_TRACEIO_ESCAPE and ASYN_TRACEIO_DRIVER____
- Using the asynRecord send the command “GET /data”____
- Look at the asynTrace output to see what was sent and what was
received.____
__ __
Mark____
__ __
__ __
[mailto:[email protected]
<mailto:[email protected]>] *On Behalf Of *Ana Malagon
*Sent:* Wednesday, February 18, 2015 12:05 PM
*To:* Kasemir, Kay
*Cc:* [email protected] <mailto:[email protected]>
*Subject:* Re: using EPICS code with HTTP port____
__ __
Hi Kay, Mark,____
Thanks for the help - so I've tried both approaches (using pcaspy to
set up an IOC, and alternatively using HTTP in IPPortConfigure for
my streamDevice application) and am running into a stumbling block
with both.____
The problem is that when I request the data I always get an array of
0's back. Here's the syntax I'm using in the streamDevice IOC (and I
know the HTTP commands are correct because they work in a telnet
session):____
/===device.proto file===/____
/getData {
out "GET /data";
in "%\$1[^\r\n]";
ExtraInput = Ignore;
}/____
/====device.db file===
record(waveform, "$(P)$(R)Data")
field(DESC, "Data array")
field(DTYP, "stream")
field(INP, "@devREDPITAYASTREAM.proto getData(20000) $(PORT)
$(A)")
field(PINI, "YES")
field(FTVL, "CHAR")
field(NELM, "32000")
}/____
For the pcaspy version, I have taken the tutorial file pysh.py,
which creates an IOC that processes shell commands
(https://code.google.com/p/pcaspy/source/browse/example/pysh.py) and
modified the OUTPUT to be of datatype "char" with a large count. I
have httpie installed, which is a library allowing me to run the
command 'http 10.95.101.75/data <http://10.95.101.75/data>' on the
command line to retrieve the data. However, when I do 'caput
MTEST:COMMMAND "http 10.95.101.75/data <http://10.95.101.75/data>"
and then 'caget MTEST:OUTPUT', I get an array of zeroes back.____
Does anything pop out as immediately suspicious?____
Thanks,____
Ana____
____
__ __
On Mon, Feb 9, 2015 at 12:58 PM, Kasemir, Kay <[email protected]
<mailto:[email protected]>> wrote:____
What Mark suggests could work, but the HTTP protocol is somewhat
verbose and the exact response of the server could vary.
To emulate
> curl http://10.95.101.75/bazaar?start=spectrum
you could try to send
GET bazaar?start=spectrum HTTP/1.1\n\n
.. and then ignore the response.
To emulate
> curl http://10.95.101.75/data
GET data HTTP/1.1\n\n
and then you need to be prepared to parse a response that looks like
HTTP/1.1 200 OK
Content-Type: text/html
Server: Whatever
Cache-Control: no-cache
Pragma: no-cache
Content-Length: 97
.. the actual data..
You should try those GET commands from a plain telnet session to the
server to see the exact response.
It might be easier to use for example python with urllib2 to
communicate with the device, and then see the recent tech-talk
discussion on how to get from python to EPICS:
* Use CA client library to write values from Python to a "real IOC"
* Use CA server library to serve the values from Python, i.e. it's
like an IOC
* Serve data from python via a simpler TCP socket protocol, read
into IOC via stream device.
Kay
On Feb 9, 2015, at 3:02 PM, Mark Rivers <[email protected]
<mailto:[email protected]>>____
wrote:
> This command should be:
> drvAsynIPPortConfigure("L0","10.95.101.75:80
<http://10.95.101.75:80> HTTP",0,0,0)
> The HTTP means that drvAsynIPPort will handle the fact that the
server will disconnect after each transaction.
> You can’t use the “curl” command in your protocol. You need to
send the actual commands that the HTTP server requires.
> It might be something like
> getData {
> out "get data";
> in "%\$1[^\r\n]";
> Mark
> From: [email protected]
<mailto:[email protected]>] On Behalf Of Ana Malagon
> Sent: Monday, February 09, 2015 1:53 PM
> To: [email protected] <mailto:[email protected]>
> Subject: using EPICS code with HTTP port
> Hi,
> I'm trying to use EPICs with a digitizer (www.redpitaya.com
<http://www.redpitaya.com>) which has a web interface - I can get
the information using curl to download the website information:
> but I'm a little confused about how to integrate these commands
in an ioc. I've set up a StreamDevice template, and I thought I
might be able to just send the curl commands by putting them in a
record:
> record(bo, "$(P)$(R)Start")
> field(DESC, "Start App")
> field(OUT, "@devREDPITAYASTREAM.proto startApp $(PORT) $(A)")
> field(ZNAM, "spectrum")
> #field(PINI, "YES")
> #field(VAL, "1")
> field(DESC, "Data string")
$(A)")
> field(PINI, "YES")
> field(FTVL, "CHAR")
> with the corresponding entries in the .proto file being:
> startApp {
> out "curl http://10.95.101.75/bazaar?start=%{spectrum}
<http://10.95.101.75/bazaar?start=%25%7bspectrum%7d>";
> getData {
> out "curl http://10.95.101.75/data";
> in "%\$1[^\r\n]";
> When I run st.cmd, the host is configured to be the IP address of
the red pitaya itself, using the HTTP port of 80:
<http://10.95.101.75:80>",0,0,0)
> I'm not sure if this is the right thing to do? In any case, when
running st.cmd with asynTraceMask enabled I get a continuous stream
of "reads"
> 2015/02/09 11:48:23.530 10.95.101.75:80 <http://10.95.101.75:80>
read.
> but it doesn't seem to respond to the commands I've made.
> Does anyone have any feeling for using Epics with HTTP commands?
> Thanks!
> Ana Malagon____
__ __
- using EPICS code with HTTP port Ana Malagon
- RE: using EPICS code with HTTP port Mark Rivers
- Re: using EPICS code with HTTP port Kasemir, Kay
- Re: using EPICS code with HTTP port Ana Malagon
RE: Error in compiling area detector. Mark Rivers
CSS: HOW TO INCLUDE ONE JAVASCRIPT FILE IN ANOTHER JAVASCRIPT FILE IN CSS ? B Chitalia/TVM/TCS
<2015>
2025
2026
Re: using EPICS code with HTTP port Rod Nussbaumer
Re: using EPICS code with HTTP port Dirk Zimoch
<2015>
2025
2026
