1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: asyn R4.26
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 27 Feb 2015 15:59:10 -0800
Hi Mark,
I am beginning to use asyn R4.26, where the new feature that you have added to allow initialization of output records, is of interest.
It works well, except I have noticed one thing.
In my case I am initializing a longout record from the device driver. It gets the value correctly, UDF is set to 0 but STAT has UDF and SEVR is INVALID. Do I need to do something else in addition to just push a new value to the record? I don't want to process the record, which most likely would put the record in a good state.
Sorry for bugging you and thanks,
Zen
RE: asyn R4.26 Mark Rivers
Prev: Re: Building custom areadetector module Andrew Gomella
Next: RE: asyn R4.26 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Qt Designer with Epics Records Andrew Rhyder
