1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Qt Designer with Epics Records
To: Kiran Francis <[email protected]>, "[email protected]" <[email protected]>
Date: Sun, 1 Mar 2015 10:48:01 +0000
Hi Kiran
You can use the QEGui application, which is part of your EPICSQt package, to open .ui files.
$ qegui yourGUI.ui
As well as presenting GUIs QEGui also provides tools including strip chart, PV inspection, PV scratch pad, message logging, archiver status, PV name search, configuration save and restore and user levels out of the box.
If you want you can also customise its meu bars and tool bars to focus on the application you are developing.
QE_QEGuiAndUserInterfaceDesign.pdf contains the user documentation for QEGui, and the QEFramework widgets. It is in the ‘Documentation’ directory of your package or at http://sourceforge.net/projects/epicsqt/files/documentation/
QEGui also integrates with Qt designer allowing GUIs to be modified on the fly if required.
This is by far the quickest way to get going, and is likely to be all you need, but you can also use the .ui file as a source file within your own home grown Qt based application. The QE widgets will look after themselves, but many of the mechanisms available in QEGui like message logging and save and restore are public and can be used in your own application to add support for QEWidgets.
Regards
Andrew
From: [email protected] [mailto:[email protected]] On Behalf Of Kiran Francis
Sent: Friday, 27 February 2015 6:57 PM
To: [email protected]
Subject: Qt Designer with Epics Records
Greetings,
I have installed Qt4 Interface Designer, QWT 6.1.2 and EPICS Qt framework 3.0.2 on CentOS 6.6 32-bit machine. I have EPCIS Base 3.14.12.4.
I can get the output in epics prompt using the channel access commands like caget, camonitor, etc. I have designed an interface for the records in the Qt Designer and obtained a .ui file.
How do i go about getting the record values in the interface? Please provide guidance or any links to tutorials or manuals if any.
Kiran Francis
Qt Designer with Epics Records Kiran Francis
Prev: Re: Using the EPICS Build/Make system to build kernel modules for linux Daron Chabot
Next: sabbatical at NSLS II Dalesio, Leo
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Qt Designer with Epics Records Kiran Francis
Next: asyn R4.26 Zenon Szalata
