1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: asyn R4.26
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Mon, 2 Mar 2015 12:55:47 -0800
Hi Mark,
I wrote a tiny test IOC which is based on asynPortDriver class. I have created a record:
record( longout, "$(P):LO:TEST"){
  field( DTYP, "asynInt32")
  field( OUT,  "@asyn($(PORT),0,1)LO_TEST")
  field( EGU,  "ms")
  info(asyn:READBACK,"1")
In the constructor, after createParams calls, I do this:
  setIntegerParam( _loTest,tv);
  callParamCallbacks( 0);
this results in VAL has the expected value, UDF 0, STAT UDF, SEVR INVALID.
I have also implemented a bo record which allows me to execute the two statements, setIntegerParam( _loTest,tv) and callParamCallbacks() with a caput command. When I do that, then the STAT and SEVR has NO_ALARM values. When I set TPRO=1 in the longout record, then when I process my bo record, I get:
scanOnce: Process CHA:SM:LO:TEST.
So all of that seems to work as you explained.
But I still am confused. I see that the longout record is not "really" processed; it did not write its VAL to the OUT link. I expected (and perhaps feared) that if the longout record gets processed as a result of giving it a new value from the device driver via this newly implemented mechanism, it would also write out the value to its OUT link. Since that is not happening, at least in my program, then the record is processed in some special way.
Anyway, I just need some confirmation that what I am seeing is correct.
Thanks Mark,
Zen
On 02/28/15 06:28, Mark Rivers wrote:
Hi Zen,
There are two separate ways to get the value from the driver into an output record.
1) The first way is to have your driver write the value to the parameter library at some point before iocInit.  Standard asyn device support always attempts to read the value from the driver in the init_record function at iocInit.  If the read returns asynSuccess then the value read is put into the VAL field and UDF is set to 0.  The record does not process at iocInit unless the PINI field is YES.  This mechanism has existed in asyn since the beginning.
2) The second way is the new feature added in asyn R4-26.  It requires that you set the info tag asyn:READBACK to 1.  In this case whenever your driver does a callback to device support the output record will process and get the new value.  This was not really intended to initialize the value at iocInit, but rather to update the record later if something other than processing that record cause the value in the driver to change.
I just did a test to verify that I believe things are working as they should.  asyn comes with a test application called testErrorsApp.  That application sets the values of some parameters in the parameter library in the constructor, and updates them periodically in a driver thread.
I just created a new simple database called testErrors1.db for that application.  Here it is:
corvette:~/devel/asyn/db>more testErrors1.db
record(longout, "$(P)LongoutInt32")
    field(DTYP, "asynInt32")
    field(OUT,  "@asyn($(PORT),$(ADDR),$(TIMEOUT))INT32_VALUE")
    field(VAL, "0")
record(longout, "$(P)LongoutInt32_PINI")
    field(PINI, "1")
    field(VAL, "0")
record(longout, "$(P)LongoutInt32_RB")
    field(VAL, "0")
record(longout, "$(P)LongoutInt32_RB_PINI")
    field(PINI, "1")
    field(VAL, "0")
It has 4 longout records.
                       PINI       asyn:READBACK present
LongoutInt32          No           No
LongoutInt32_PINI     Yes          No
LongoutInt32_RB       No           Yes
LongoutInt32_RB_PINI  Yes          Yes
I then loaded this database into an IOC running the testErrorsApp application.  This is the output of dbpr for each of those records with level 10 of output.
epics> dbpr testErrors:LongoutInt32 10
ACKS: NO_ALARM      ACKT: YES           ADEL: 0             ALST: 1
ASG:                ASP: (nil)          BKPT: 00            DESC:
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DOL:CONSTANT        DPVT: 0x2578c70     DRVH: 0             DRVL: 0
DSET: 0x7f61cceaa900                    DTYP: asynInt32     EGU:
EVNT: 0             FLNK:CONSTANT 0     HHSV: NO_ALARM      HIGH: 0
HIHI: 0             HOPR: 0             HSV: NO_ALARM       HYST: 0
IVOA: Continue normally                 IVOV: 0             LALM: 1
LCNT: 0             LLSV: NO_ALARM      LOLO: 0             LOPR: 0
LOW: 0              LSET: 0x25887f0     LSV: NO_ALARM       MDEL: 0
MLIS: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
MLOK: f0 8a 57 02 00 00 00 00           MLST: 1
NAME: testErrors:LongoutInt32           NSEV: NO_ALARM      NSTA: NO_ALARM
OMSL: supervisory   OUT:INST_IO @asyn(PORT1,0,1)INT32_VALUE PACT: 0
PHAS: 0             PINI: NO            PPN: (nil)          PPNR: (nil)
PRIO: LOW           PROC: 0             PUTF: 0             RDES: 0x2532a30
RPRO: 0             RSET: 0x7f61ccc34180                    SCAN: Passive
SDIS:CONSTANT       SEVR: INVALID       SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SPVT: (nil)         STAT: UDF
TIME: <undefined>   TPRO: 0             TSE: 0              TSEL:CONSTANT
UDF: 0              VAL: 1
epics> dbpr testErrors:LongoutInt32_PINI 10
DOL:CONSTANT        DPVT: 0x2586350     DRVH: 0             DRVL: 0
LOW: 0              LSET: 0x2588810     LSV: NO_ALARM       MDEL: 0
MLOK: 60 8b 57 02 00 00 00 00           MLST: 1
NAME: testErrors:LongoutInt32_PINI      NSEV: NO_ALARM      NSTA: NO_ALARM
PHAS: 0             PINI: YES           PPN: (nil)          PPNR: (nil)
SDIS:CONSTANT       SEVR: NO_ALARM      SIML:CONSTANT       SIMM: NO
SIMS: NO_ALARM      SIOL:CONSTANT       SPVT: (nil)         STAT: NO_ALARM
TIME: 2015-02-28 08:04:44.076227816     TPRO: 0             TSE: 0
TSEL:CONSTANT       UDF: 0              VAL: 1
epics> dbpr testErrors:LongoutInt32_RB 10
DOL:CONSTANT        DPVT: 0x2586c80     DRVH: 0             DRVL: 0
LOW: 0              LSET: 0x2588830     LSV: NO_ALARM       MDEL: 0
MLOK: d0 8b 57 02 00 00 00 00           MLST: 1
NAME: testErrors:LongoutInt32_RB        NSEV: NO_ALARM      NSTA: NO_ALARM
TIME: 2015-02-28 08:04:44.173729522     TPRO: 0             TSE: 0
epics> dbpr testErrors:LongoutInt32_RB_PINI 10
DOL:CONSTANT        DPVT: 0x25879b0     DRVH: 0             DRVL: 0
LOW: 0              LSET: 0x2588850     LSV: NO_ALARM       MDEL: 0
MLOK: 40 8c 57 02 00 00 00 00           MLST: 1
NAME: testErrors:LongoutInt32_RB_PINI   NSEV: NO_ALARM      NSTA: NO_ALARM
TIME: 2015-02-28 08:04:44.173736304     TPRO: 0             TSE: 0
Here is a summary of the UDR, STAT and SEVR fields of each of those records.
                                     UDF    STAT      SEVR
testErrors:LongoutInt32              0     UDF       INVALID
testErrors:LongoutInt32_PINI         0     NO_ALARM  NO_ALARM
testErrors:LongoutInt32_RB           0     NO_ALARM  NO_ALARM
testErrors:LongoutInt32_RB_PINI      0     NO_ALARM  NO_ALARM
This is exactly what I expect.
All records have UDF=0 because the value was successfully read from the driver at in init_record in the device support.
For testErrors:LongoutInt32 the record has never processed because PINI=NO and the asyn:READBACK info tag is not present.  It thus has STAT=UDF and SEVR=INVALID.  All of the other records have processed, either because they have PINI=YES or because they have the asyn:READBACK tag.  Because they have processed STAT and SEVR are both NO_ALARM.
I hope this clarifies things.
Sent: Friday, February 27, 2015 11:09 PM
To: Mark Rivers; [email protected]
Hi Mark,
I am using asynPortDriver class. The records are initialized after IOC
init and the record in question looks like this:
epics> dbpr CHA:LO:2531-1-2:CWORD,3
ACKS: NO_ALARM ACKT: YES ADEL: 0 ALST: 0
ASG: BKPT: 00 DESC: DISA: 0
DISP: 0 DISS: NO_ALARM DISV: 1 DOL:CONSTANT
DRVH: 0 DRVL: 0 DTYP: asynInt32 EGU:
IVOA: Continue normally IVOV: 0 LALM: 0
LOW: 0 LSV: NO_ALARM MDEL: 0 MLST: 0
NAME: CHA:LO:2531-1-2:CWORD NSEV: NO_ALARM NSTA: NO_ALARM
OMSL: supervisory OUT:INST_IO @asyn(2531-1,0,1)LO_CWORD PACT: 0
PHAS: 0 PINI: NO PRIO: LOW PROC: 0
PUTF: 0 RPRO: 0 SCAN: Passive SDIS:CONSTANT
SEVR: INVALID SIML:CONSTANT SIMM: NO SIMS: NO_ALARM
SIOL:CONSTANT STAT: UDF TIME: 2015-02-27 15:41:07.126179705
TPRO: 0 TSE: 0 TSEL:CONSTANT UDF: 0
VAL: 0
epics>
I verified that processing the record, it goes into a healthy state. I
suppose there is no harm to process the record, since it will write back
to the hardware which was just read in. The reason I noticed this is
that the EDM byte monitor widget displays the data as uninitialized...
The question still remains, since the record should have been processed
when the value was written to it and yet the record looks like it was
not processed, so what happened?
Thanks Mark,
Zen
On 02/27/15 16:54, Mark Rivers wrote:
I think STAT and SEVR only get set when the record processes.
When are you doing the callback to device support, before or after iocInit?
If you do the callback after iocInit then the callback will cause the record to process, because it calls scanOnce(). However, if you call it before iocInit it will not call scanOnce() because that will crash the IOC.
Are you using the asynPortDriver C++ base class? If so that takes care of the problem for you because it has a thread that waits for interruptAccept to be true, and then does all of the callbacks to device support.
-----Original Message-----
Sent: Friday, February 27, 2015 5:59 PM
Subject: asyn R4.26
Hi Mark,
I am beginning to use asyn R4.26, where the new feature that you have
added to allow initialization of output records, is of interest.
It works well, except I have noticed one thing.
In my case I am initializing a longout record from the device driver.
It gets the value correctly, UDF is set to 0 but STAT has UDF and SEVR
is INVALID. Do I need to do something else in addition to just push a
new value to the record? I don't want to process the record, which most
likely would put the record in a good state.
Sorry for bugging you and thanks,
Zen
RE: asyn R4.26 Mark Rivers
Re: asyn R4.26 Benjamin Franksen
asyn R4.26 Zenon Szalata
Re: asyn R4.26 Zenon Szalata
Prev: Re: Using sCalcout record Chanaka De Silva
Next: RE: asyn R4.26 Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: asyn R4.26 Mark Rivers
