On 03/03/2015 11:04 AM, Kasemir, Kay wrote:
> Until the PV is initialized, I get the same
> No conversion between src & dest types no conversion between event
> app type=16 and DBR type=18 Element count=60
> error.
The implication is that pcaspy is presenting an uninitialized channel's
value to the cas as some type which gdd can't convert into to an array
of chars. The answer may be as simple as always initializing the value
of a string channel to be an empty string.
- Andrew
Doctorow's Law: Anytime someone puts a lock on something you own,
against your wishes, and doesn't give you the key, they're
not doing it for your benefit.
- Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
- Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
- "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
- Re: "No conversion between src & dest" warning with pcaspy Andrew Johnson
<2015>
2025
2026
<2015>
2025
2026
