1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: "No conversion between src & dest" warning with pcaspy
To: Andrew Johnson <[email protected]>, [email protected]
Date: Tue, 03 Mar 2015 09:36:44 -0800
On Tue, Mar 03 2015, Andrew Johnson <[email protected]> wrote:
> On 03/03/2015 11:04 AM, Kasemir, Kay wrote:
>> Until the PV is initialized, I get the same
>>   No conversion between src & dest types no conversion between event
>>   app type=16 and DBR type=18 Element count=60
>> error.
> The implication is that pcaspy is presenting an uninitialized channel's
> value to the cas as some type which gdd can't convert into to an array
> of chars. The answer may be as simple as always initializing the value
> of a string channel to be an empty string.
I actually tried that as well, specifying an initial "value" for the
record to be the empty string (which is supposed to be the default
anyway) behaves exactly like specifying no initial value at all, and
produces the same messages.
But I agree that it appears there's something about what pcaspy is
presenting that might be problematic.
jamie.
Attachment: signature.asc
Description: PGP signature
"No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Re: "No conversion between src & dest" warning with pcaspy Andrew Johnson
Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
Prev: Re: "No conversion between src & dest" warning with pcaspy Kasemir, Kay
Next: Re: "No conversion between src & dest" warning with pcaspy Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: "No conversion between src & dest" warning with pcaspy Wang Xiaoqiang (PSI)
Next: error on the IOC shell for asyn driver Vishnu Patel
