1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: using PI C-863 Mercury motor controller with linux
To: Heinz Junkes <[email protected]>
Cc: "<[email protected]>" <[email protected]>, "<[email protected]>" <[email protected]>, "<[email protected]>" <[email protected]>
Date: Fri, 13 Mar 2015 14:04:48 +0000
The C-663 uses the PI General Command Set, and there's also Asyn based support in the motor support module:
http://www.aps.anl.gov/bcda/synApps/motor/
I'm currently using two C-663 controllers in a RS232 daisy chain configuration via a Moxa. The motor module doesn't contain the daisy chain support, but does work point-to-point.
The IOC startup file would contain the following commands:
drvAsynIPPortConfigure("PI1","10.112.2.4:4001",0,0,0)
PI_GCS2_CreateController("PIC1", "PI1", 1, 0, 0, 500, 1000)
Then the motor record would use the "PIC1" asyn port.
Cheers,
Matt
On Mar 13, 2015, at 8:00 AM, Heinz Junkes <[email protected]> wrote:
> Hi Enrico,
> I run a similar controller C-663 Mercury Step but using the serial (RS232) port.
> I can send to you the proto and db - files to use the controller with streamdevice.
> Best regards,
> Heinz
>> On 13.03.2015, at 10:59, Enrico Virgilli <[email protected]> wrote:
>> Dear staff,
>> I have a PI C-863 Mercury motor controller
>> http://www.physikinstrumente.com/en/products/prdetail.php?sortnr=900605
>> that I would like to control with linux. The connection is
>> USB, and at the moment I am successfully using it with a desktop with
>> windows.
>> I have not found drivers or references on how to do it and I am a really
>> newbye in this sense. Can you help me giving some  reference or
>> free software to test it?
>> SIncerely,
>> Enrico
>> Enrico Virgilli, PhD
>> Physics and Earth Sciences Department
>> University of Ferrara, Via Saragat, 1
>> 44122 Ferrara, Italy
>> . Building C, room 424
>> Office phone: +39 0532-974366
>> . Building H, LARIX Facility
>> Laboratory phone: +39 0532-974638
>> mobile: +39 333-6405036
>> e-mail: [email protected]
>> skype-me: dantedante777
using PI C-863 Mercury motor controller with linux Enrico Virgilli
Re: using PI C-863 Mercury motor controller with linux Heinz Junkes
Prev: Re: using PI C-863 Mercury motor controller with linux Heinz Junkes
Next: RE: Base 3.14.12.5-rc1 Available freddie.akeroyd
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: CSS - how to read waveform of CHARS (or STRINGS) in a script? Isabella Rey
