1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: CSS - how to read waveform of CHARS (or STRINGS) in a script?
To: [email protected]
Date: Fri, 13 Mar 2015 19:01:41 +0000
Hi All,
In CSS (Windows), I am trying to read a waveform of CHARS inside a Python script.
When I do PVUtil.getString, I get displayed a sequence of numbers instead of characters.
Is there any way to get the text in the script??
If I create a text update widget pointing at the waveform, I get the text correctly, I want to get the same in the script.
If it helps:
for what I need to do, I can also have a waveform of strings, rather than chars, and I need to extract the strings in the Python script.
Whichever works would be fine!
Cheers,
Isabella
Re: CSS - how to read waveform of CHARS (or STRINGS) in a script? John Hammonds
Re: CSS - how to read waveform of CHARS (or STRINGS) in a script? Hugo Slepicka
Prev: Re: Base 3.14.12.5-rc1 Available Andrew Johnson
Next: Re: CSS - how to read waveform of CHARS (or STRINGS) in a script? John Hammonds
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: using PI C-863 Mercury motor controller with linux Pearson, Matthew R.
