1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: CSS - how to read waveform of CHARS (or STRINGS) in a script?
To: <[email protected]>
Date: Fri, 13 Mar 2015 14:15:04 -0500
Isabella,
I do not remember all of the specifics at the moment but you need to look at formatting for the string.  The text field in BOY has a formatting option to translate the waveform into characters.  You will need to apply this same formatting to get the string out.  It has been a couple of years since I looked at the code but I believe there is a separate class to handle the formatting.
John
On 3/13/2015 2:01 PM, Isabella Rey wrote:
Hi All,
In CSS (Windows), I am trying to read a waveform of CHARS inside a Python script.
When I do PVUtil.getString, I get displayed a sequence of numbers instead of characters.
Is there any way to get the text in the script??
If I create a text update widget pointing at the waveform, I get the text correctly, I want to get the same in the script.
If it helps:
for what I need to do, I can also have a waveform of strings, rather than chars, and I need to extract the strings in the Python script.
Whichever works would be fine!
Cheers,
Isabella
John Hammonds
Software Services Group
Advanced Photon Source
Argonne National Laboratory
[email protected]
CSS - how to read waveform of CHARS (or STRINGS) in a script? Isabella Rey
Prev: CSS - how to read waveform of CHARS (or STRINGS) in a script? Isabella Rey
Next: Re: CSS - how to read waveform of CHARS (or STRINGS) in a script? Hugo Slepicka
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
