1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Removing the motor record's RINP input link
To: EPICS <[email protected]>
Date: Fri, 13 Mar 2015 16:23:17 -0500
Recent changes to the motor record will make the "RMP Input Link" (RINP) redundant and I am considering removing it.
The RINP field is only used by the motor record's "Soft Channel" device support to allow it to read "raw" integer values. All applications here at the APS that use Soft Channel device support use the alternative input link; "Readback Location Input Link" (RDBL).
With motor module R6-10, applications using RINP will have to switch to RDBL and set the "Readback Step Size" field (RRES) to an appropriate value. Anyone using the motor record's RINP field, please contact me so we can insure a smooth transition.
Ron
Prev: logarithmic 2-D image data Pearson, Matthew R.
Next: Re: logarithmic 2-D image data Matthew D. Moore
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: logarithmic 2-D image data Mark Rivers
Next: SNL: state change statement in entry block Eric Williams
