1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: logarithmic 2-D image data
To: "Matthew D. Moore" <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 13 Mar 2015 22:37:00 +0000
Does that continue to be applied to a series of incoming images, or only to the current single image?
From: [email protected] [[email protected]] on behalf of Matthew D. Moore [[email protected]]
Sent: Friday, March 13, 2015 5:02 PM
To: [email protected]
Subject: Re: logarithmic 2-D image data
Matt,
You could use the areaDetector Image plugin and imageJ and the use Log functionality (under Process>Math).
Matt
On 3/13/15 4:21 PM, Pearson, Matthew R. wrote:
We have a new requirement to display logarithmic 2-D detector data.
We're using CSS, and the X/Y widget that we use for 1-D plots can do logarithmic scales on either axis, but the Intensity widget can't display log data. I think that might be a worthwhile addition, perhaps to the new Intensity widget.
It might also be a useful addition to the areaDetector processing plugin, which is how I'd do it for our specific areaDetector based application. That wouldn't take too long to add as a new feature.
Anyone already done something similar, either in OPI clients or server side?
Cheers,
Matt
Data Acquisition and Control Engineer
Spallation Neutron Source
Oak Ridge National Lab
logarithmic 2-D image data Pearson, Matthew R.
Re: logarithmic 2-D image data Matthew D. Moore
Prev: Re: logarithmic 2-D image data Matthew D. Moore
Next: Re: VDCT for Windows ? Konrad, Martin
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Removing the motor record's RINP input link Ron Sluiter
