1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Making EPICS IOC admin tasks easier for end-users?
Date: Mon, 16 Mar 2015 16:41:55 +0000
Hi:
On Mar 16, 2015, at 12:04 PM, "Lauk Daniel Johannes (PSI)" <[email protected]<mailto:[email protected]>>
 wrote:
We developed a web-based GUI for this. I attached a screenshot.
If you’re interested, let me know.
Neat!
We have a related setup for beam lines. Our emphasis is on providing a way to start/stop IOCs as the devices on the beam line change, meant for users who add/remove beam line devices and need to enable/disable IOCs, but who don't necessarily work on IOC databases etc.
For a screenshot, see "IOC Control" slide in my presentation at the 2014 EPICS meeting in Lanzhou.
Our IOCs run under procServ. Compared to the PSI web interface, we leave the configuration (name of IOC, procServ port, startup script, ..) out of the web interface.
When we create a new IOC, we need to manually add it to some file on the beam line which lists all IOCs.
The idea of the web interface is to list all the available IOCs, to mark their desired state as active or not, and to update the actually running IOCs to the desired set of running IOCs.
For example, the IOC for a certain sample environment device can be marked as inactive while that piece of hardware is absent from the beam line.
Once somebody puts that device back onto the beam line, they can mark the IOC as "active" and start it.
Or push "update" which will start all IOCs that should be active but aren't, respectively stop all IOCs that are running but shouldn't be.
In case the Linux server gets rebooted, it will automatically start all IOCs that were last marked as 'active'.
Kay
RE: Making EPICS IOC admin tasks easier for end-users? Lauk Daniel Johannes (PSI)
Prev: RE: Asyn record proccessing( read functions) during PINI=YES Patel Jignesh
Next: RE: Asyn record proccessing( read functions) during PINI=YES Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: Making EPICS IOC admin tasks easier for end-users? tom.cobb
Next: RE: Making EPICS IOC admin tasks easier for end-users? Lauk Daniel Johannes (PSI)
