This is published here:
http://controls.diamond.ac.uk/downloads/support/procServControl/
Tom Cobb
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of [email protected]
> Sent: 16 March 2015 09:11
> To: [email protected]; [email protected]; [email protected]
> Subject: RE: Making EPICS IOC admin tasks easier for end-users?
> On beamlines at Diamond we have solved this with a state notation
> language application (another IOC) which controls and monitors the
> state of procServ as a client. So each beamline has a "procServ control
> IOC" that provide control and monitoring of all the soft-iocs on that
> beamline. The users can then control the soft-IOCs directly through an
> EDM screen (see attached screenshot) or any other CA client.
> We can publish our "procServControl" support module if this is of
> interest...
> Cheers,
> Ulrik
> From: [email protected] [[email protected]] on
> behalf of Ralph Lange [[email protected]]
> Sent: 15 March 2015 20:11
> To: EPICS Tech-Talk
> Subject: Re: Making EPICS IOC admin tasks easier for end-users?
> Hi Andrew,
> Yup - if you want to allow restarting through Channel Access, that's
> the
> way to do it.
> With the appropriate command line option, procServ will restart any
> child process that exits. On regular IOCs, devIocStats is a portable
> way
> to have CA execute a reset/exit. On your python IOCs, you will have to
> add one PV that calls exit() when it is written to.
> The minimum common PV that you can use to show the IOC is alive would
> be
> the PV you use to issue the reset. If you add the functionality to the
> python IOCs, that PV can be made common across all your IOCs.
> Another option would be to use procServ's kill/restart command to
> restart the IOC. That does not need devIocStats or any addition to the
> python IOCs, but needs a bit more thought on the client side: The
> button
> will have to connect to the procServ session (using telnet or netcat)
> and send the restart control character. You would have to find a
> reliable way to to that (start with echoing the control character to
> netcat).
> Advantage: works with*any* child of procServ, not just IOCs.
> Disadvantages: you would still need a common PV to show the IOC is up,
> and the mechanism needs to be configured (IP and port for each IOC),
> while in the other case the reset PV name can be nice and generic, and
> you don't need to know the procServ ports.
> Cheers,
> ~Ralph
> On 15/03/2015 20:46, Andrew Gomella wrote:
> > Hi everyone,
> > For some context, we are constantly switching hardware in and out so
> > we are constantly stopping/starting soft IOC's. Some of our users
> only
> > use EPICS rarely, and I would like to be able to tell them (over the
> > phone for instance) to "restart ______ IOC" without walking through a
> > multi-step procedure.
> > Right now we can make it very easy for end users to start IOC's by
> > using the "execute shell script" button on caqtdm (or MEDM). However,
> > what I would like is a way for the end user to see which IOC's are
> > running, and have a few simple buttons like start/stop to control
> them.
> > I was thinking of installing both procserv and devIocStats and using
> > these together. (Though deviocstats won't work with several of our
> > python channel access servers)
> > I was thinking a simple, not very elegant way, would be to choose
> some
> > arbitrary PV from each given IOC and monitor that to determine
> whether
> > to indicate to the end user whether the IOC is online.
> > Look forward to hearing any suggestions!
> > Thanks,
> > Andrew
> This e-mail and any attachments may contain confidential, copyright and
> or privileged material, and are for the use of the intended addressee
> only. If you are not the intended addressee or an authorised recipient
> of the addressee please notify us of receipt by returning the e-mail
> and do not use, copy, retain, distribute or disclose the information in
> or attached to the e-mail.
> Any opinions expressed within this e-mail are those of the individual
> and not necessarily of Diamond Light Source Ltd.
> Diamond Light Source Ltd. cannot guarantee that this e-mail or any
> attachments are free from viruses and we cannot accept liability for
> any damage which you may sustain as a result of software viruses which
> may be transmitted in or with the message.
> Diamond Light Source Limited (company no. 4375679). Registered in
> England and Wales with its registered office at Diamond House, Harwell
> Science and Innovation Campus, Didcot, Oxfordshire, OX11 0DE, United
> Kingdom
- Making EPICS IOC admin tasks easier for end-users? Andrew Gomella
- Re: Making EPICS IOC admin tasks easier for end-users? Ralph Lange
- RE: Making EPICS IOC admin tasks easier for end-users? ulrik.pedersen
RE: Making EPICS IOC admin tasks easier for end-users? Lauk Daniel Johannes (PSI)
RE: Asyn record proccessing( read functions) during PINI=YES Patel Jignesh
<2015>
2025
2026
Re: Making EPICS IOC admin tasks easier for end-users? Kasemir, Kay
<2015>
2025
2026
