1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Questions about EPICSv4 (Ricardo Herrero)
To: [email protected]
Date: Mon, 16 Mar 2015 13:52:13 -0400
On 03/16/2015 10:49 AM, Ricardo Herrero wrote:
Hello,
I´m still trying to get a Monitor to work in JAVA, and even I´m learning a lot, there are many things I don´t understand yet. If someone could help me with these questions I would really appreciate it.
1. There´s an package in pvData called Monitor, in which you have MonitorAlgorithm class, Do I have to create the algorithm of the Monitor? MonitorQueue, do I need to create a Queue to store the Monitor Elements?
2. Object Monitor does exist both in server and client, or (in the server side) do I just have to create a PVAccessServer and it creates automatically a Monitor?
3. What is the function of the Requester, I can´t see the way they work, its functions.
4. I have also found org.epics.pvaccess.server.impl.remote.handlers, they seem to have implemented most of the interfaces, like MonitorHandler, how can I use them? Do I avoid using directly Monitor, Channel and PVAccessServer, on behalf of the MonitorHandler?
5. When I try to create a Server throught ServerFactory I have seen that the Threads are created with the name PVAccessServer, hardcoded, and I don´t know how can I change it.
Any help will be welcomed, thanks in advance.
Yours, Ricardo Herrero
Quick answer.
There is a new mercurial repository pvDatabaseJava.
Please try it.
Longer answer.
There is a mercurial repository that is not a component of the V4 releases named pvIOCJava. It has lots of code including a complete implementation of a local pvAccess server. It also has lots that seemed, at the time, to be good ideas but no one has bought in.
For C++, pvDatabaseCPP is a component of the latest V4 release.
It provides a complete implementation of a local pvAccess server except channelRPC which is provided by pvAccess itself.
It  does not implement any of the other features that pvIOCJava provides.
I hope that pvDatabaseJava will be a component of the next V4 release.
It also has a complete implementation of a local pvAccess server except channelRPC.
And again does not implement any of the other features of pvIOCJava.
What you have to do to implement a service is to provide a PVStructure with the data your service requires and a process method. pvDatabase does the rest, i.e. implements ChannelProvider, Channel, ChannelGet, ChannelPut, ChannelPutGet, Monitor, and ChannelArray.
With regards to monitor plugins.
I implemented something in pvIOCJava but again no one bought in.
So for now pvDatabaseJava does nothing for monitor plugins.
For now the only way to get pvDatabaseJava is to get it from the mercurial repository.
Hope this helps.
Also if you are implementing pvAccess client code then please look at easyPVAJava.
It is part of the latest V4 release.
easyPVACPP is currently under development.
Marty Kraimer
Questions about EPICSv4 (Ricardo Herrero) Ricardo Herrero
Prev: Re: SNL: state change statement in entry block Eric Williams
Next: Re: MEDM issues Jennings, Guy
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Questions about EPICSv4 (Ricardo Herrero) Ricardo Herrero
Next: caQtDM evaluation at SLAC Babbitt, Alisha
