1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: pyepics not updating pv.enum_strs after connection
To: EPICS tech-talk <[email protected]>
Date: Wed, 18 Mar 2015 14:11:26 -0700
Hi, folks.  I'm having an issue with pyepics and ENUM records.  I'm
initializing a PV from a device as follows:
dev = Device(prefix)
pv = dev.PV(attr, connect=False, connection_callback=connection_callback)
pv.add_callback(callback)
This all seems to work fine and as expected, except that the pv supplied
as a keyword argument to the connection_callback and callback functions
never has the pv.enum_strs attribute set for ENUM records, even after
connection has been established.  This means the ENUMs can't ever be
resolved as strings.
I'm using pyepics 3.2.1, and I assume this is a bug in this version that
has maybe (hopefully) been resolved upstream.  In the mean time, does
anyone know a workaround by which I can force the pv to update the
enum_strs attribute, or at least a way I can retrieve it from the server
so that I can update it manually?
Thanks in advance for any help.
jamie.
Attachment: signature.asc
Description: PGP signature
Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Prev: RE: Base 3.14.12.5-rc1 Available freddie.akeroyd
Next: Re: pyepics not updating pv.enum_strs after connection Jameson Graef Rollins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Increment array counter for NDFileModeSingle Hinko Kocevar
