1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: EDM -ctl opens new window instead of raising old one
To: [email protected]
Date: Wed, 18 Mar 2015 16:45:31 -0700 (PDT)
I start EDM with a command like this:
  edm -x -ctl UI:Alert main.edl
Then the large display described by main.edl appears.  When I write
'alert.edl' to UI:Alert, the smaller message described by
alert.edl pops up, floating over the large display.
But then, other activities can cause the large display to cover the
message.  I try to raise the message to the top again by writing
'alert.edl' to UI:Alert again, but instead I get a new window also
displaying alert.edl, in addition to the older one (which is still
obscured under main.edl).  Each write to UI:Alert creates a new
window.
I see this behavior when I write alert.edl to UI:Alert via OUT from an
scalcout record, or when I command: dbpf UI:Alert alert.edl in the
ioc shell.
When I write alert.edl to UI:Alert and the message pops up, dbgf
UI:Alert always shows an empty string (not 'alert.edl' as I
expected).
I see this behavior when UI:Alert is a stringin, or when it is a stringout.
In both cases, I define it this way, without any explicit field definitions:
  record(stringin, "UI:Alert") {
Is there anything I can do so that writing to UI:Alert will raise an
existing display to the top, instead of opening another instance of
the same display?
Alternatively, is there some other way to force a display to the top, or
(better yet) create the display so it always remains on top?
Jon Jacky
Re: EDM -ctl opens new window instead of raising old one John William Sinclair
Prev: Announcing carchivetools Michael Davidsaver
Next: Re: pyepics not updating pv.enum_strs after connection Matt Newville
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: EDM -ctl opens new window instead of raising old one John William Sinclair
