1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: procServ+devIocStats questions
To: EPICS Tech-Talk <[email protected]>
Date: Wed, 25 Mar 2015 16:43:45 +0100
Hi Freddie,
On 25/03/2015 14:16, [email protected] wrote:
I enclose a diff of the changes I have to procServ 2.6.0 (compiled under Cygwin) which I found useful when using it to manage native windows IOCs. In summary they:
* add spawned process to a windows job object. Killing the "process group" from Cygwin doesn't always clean everything up. For example, if the CS Studio ArchiveEngine is being managed it is killed, but not the java.exe JVM process it spawns. Job objects are inherited by spawned processes, so both are now killed automatically.
* hide console command window that is created
* fix small memory leak in clientItem() destructor
* automatic daily log file rotation - log file name is parsed by strftime() to determine filename format
* updated libtelnet to never version (fixes an off by one malloc error)
* Added remakeConnection() method to acceptItem - after a lot of connect/disconnect calls  I found procServ stopped accepting connections.
* windows does not do line buffering, so need to look for EOL to write timestamps in correct place on output line
* handle SIGTTIN, set SNDTIMEO on socket and also do select() before write to process. I had some hangs in cygwin   fhandler_pty_master::doecho()   and these changes were part of debugging this, probably not necessary anymore.
Thanks a lot!
I will incorporate your changes as soon as I find time.
~Ralph
procServ+devIocStats questions Alireza Panna
RE: procServ+devIocStats questions freddie.akeroyd
Prev: multiple asynRecord communication conflict Zohar, Sioan
Next: Re: pyepics not updating pv.enum_strs after connection Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: procServ+devIocStats questions freddie.akeroyd
Next: multiple asynRecord communication conflict Zohar, Sioan
