1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: multiple asynRecord communication conflict
Date: Wed, 25 Mar 2015 15:21:43 +0000
I have several asynRecord instances running in a softIOC talking to a single serial port and I suspect they are conflicting.
Everything runs fine for several hours, and then the asynRecord writes stop reaching the serial port.  (I confirmed this by sniffing the serial output using the serial port from another computer).
This error is not observed when there is only one instance of the asynRecord.
This problem does not occur on every computer, so perhaps it depends on environment settings?
I've tried daisy chaining the asynRecords by flnk'ing them.  Two asynRecords are set to scan = passive, and the other is set to scan = 1 second. I thought this would prevent the possibility of multiple asynrecord instances from talking to the port at once, but the problem persists.
Thanks in advance for your help.
Sioan
RE: multiple asynRecord communication conflict Mark Rivers
Prev: Re: procServ+devIocStats questions Kasemir, Kay
Next: Re: procServ+devIocStats questions Ralph Lange
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: procServ+devIocStats questions Ralph Lange
Next: RE: multiple asynRecord communication conflict Mark Rivers
