1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record issue - to set aother record value
To: "Amien Crombie [TLABS]" <[email protected]>
Cc: "<[email protected]>" <[email protected]>
Date: Thu, 26 Mar 2015 13:51:44 +0000
You could use a stringout record forward linked from each calcrange record, like:
record(acalcout, "$(dev):calcrange1")
     field(FLNK, "$(dev):calcrange1_EGU")
record(stringout, "$(dev):calcrange1_EGU")
    field(VAL, "mA")
    field(OUT, "$(dev):trueval.EGU PP")
Cheers,
Matt
On Mar 26, 2015, at 8:34 AM, Amien Crombie [TLABS] <[email protected]> wrote:
> Hi
> Below I have a few records and would like to know how I can set value for "$(dev):trueval"'s EGU.
> This text changes according to what the range is at the moment.
> So for example, if I call "calcrange2" , I need to set "$(dev):trueval.EGU" to "mA" or
> "calcrange4" , I need to set "$(dev):trueval.EGU" to "uA"  etc....
> Any help would be appreciated.
>     record   (dfanout, "$(dev):checkrange")
>       field(OUTA,    "$(dev):calcrange1 PP")
>       field(OUTB,    "$(dev):calcrange2 PP")
>       field(OUTC,    "$(dev):calcrange3 PP")
>       field(OUTD,    "$(dev):calcrange4 PP")
>       field(OUTE,    "$(dev):calcrange5 PP")
>       field(OUTF,    "$(dev):calcrange6 PP")
>       field(OUTG,    "$(dev):calcrange7 PP")
>       field(OUTH,    "$(dev):calcrange8 PP")
>       field(SELL,    "$(dev):range")
>       field(SELM,    "Specified")
>           field(DTYP,  "Soft Channel")
>           field(INPA,  "$(dev):rawval")
>           field(INPB,  "$(dev):range")
>           field(INPC,  "$(dev):offsetR1")
>           field(INPD,  "10.0")
>           field(OOPT,  "Every Time")
>           field(DOPT,  "Use CALC")
>           field(CALC,  "B==1?((A-C)/32767.2) * D:A")
>           field(OUT,   "$(dev):trueval PP")
>    record(acalcout, "$(dev):calcrange2")
>           field(INPD,  "10.0")
>           field(CALC,  "B==2?((A-C)/32767.2) * D:A")
>    record(ai,         "$(dev):trueval")
>           field(EGU,    " mA")
> Thanks
> Amien
> Cape Town
Re: Record issue - to set aother record value Amien Crombie [TLABS]
Prev: Re: Record issue - to set aother record value Ralph Lange
Next: Re: Record issue - to set aother record value Amien Crombie [TLABS]
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <2015>  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
