1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Record issue - to set aother record value
To: EPICS Tech-Talk <[email protected]>
Date: Thu, 26 Mar 2015 14:50:08 +0100
Sorry for the noise - again.
A single sseq record from synApps could also do the job.
Alternatively, using standard records, you can use a sel record firing one of a set of constant stringout records that all point to the same EGU field.
SNL seems a bit too big a cannon....
~Ralph
On 26/03/2015 13:48, Arnold, Ned D. wrote:
You could use the scalcout record from synApps or a state notation (SNL) program ...
   Ned
From: [email protected] [[email protected]] on behalf of Amien Crombie [TLABS] [[email protected]]
Sent: Thursday, March 26, 2015 07:34 AM
To: [email protected]
Subject: Record issue - to set aother record value
Hi
Below I have a few records and would like to know how I can set value for "
$(dev):trueval"'s EGU.
This text changes according to what the range is at the moment.
So for example, if I call "calcrange2" , I need to set "$(dev):trueval.EGU" to "mA" or
"calcrange4" , I need to set "$(dev):trueval.EGU" to "uA"  etc....
Any help would be appreciated.
    record   (dfanout, "$(dev):checkrange")
      field(OUTA,    "$(dev):calcrange1 PP")
      field(OUTB,    "$(dev):calcrange2 PP")
      field(OUTC,    "$(dev):calcrange3 PP")
      field(OUTD,    "$(dev):calcrange4 PP")
      field(OUTE,    "$(dev):calcrange5 PP")
      field(OUTF,    "$(dev):calcrange6 PP")
      field(OUTG,    "$(dev):calcrange7 PP")
      field(OUTH,    "$(dev):calcrange8 PP")
      field(SELL,    "$(dev):range")
      field(SELM,    "Specified")
    record(acalcout, "$(dev):calcrange1")
          field(DTYP,  "Soft Channel")
          field(INPA,  "$(dev):rawval")
          field(INPB,  "$(dev):range")
          field(INPC,  "$(dev):offsetR1")
          field(INPD,  "10.0")
          field(OOPT,  "Every Time")
          field(DOPT,  "Use CALC")
          field(CALC,  "B==1?((A-C)/32767.2) * D:A")
          field(OUT,   "$(dev):trueval PP")
   record(acalcout, "$(dev):calcrange2")
          field(INPD,  "10.0")
          field(CALC,  "B==2?((A-C)/32767.2) * D:A")
   record(ai,         "$(dev):trueval")
          field(EGU,    " mA")
Thanks
Amien
Cape Town
Record issue - to set aother record value Amien Crombie [TLABS]
RE: Record issue - to set aother record value Arnold, Ned D.
Prev: Re: Record issue - to set aother record value Ralph Lange
Next: Re: Record issue - to set aother record value Pearson, Matthew R.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
