Subject: |
Re: Stream device: how to send waveform of chars without null terminator? |
Ralph Lange <[email protected]> |
To: |
EPICS Tech-Talk <[email protected]> |
Date: |
Wed, 01 Apr 2015 11:44:28 +0200 |
Have you tried using "%s" for the string output?
~Ralph
On 01/04/2015 10:44, Isabella Rey wrote:
Hi All,
I have a device to which I need to send a file path followed by a number:
example:
load_curve C:\pulse.txt 3870
The file path is stored in the database as a waveform of chars.
When I run the protocol stream device sends (what I think is) a null
terminator after the file path:
device receives:
load_curve C:\pulse.txt\x00 3870
Is there any way of getting rid of the \x00 terminator?
Below I copy my protocol and the database records.
Cheers,
Isabella
I've defined the protocol in stream device as:
load_curve
out "load_curve %(\$1)c %(\$2)i";
in "%(\$1:\$2)b";
and in the database I have:
record(bo, "DEV:LOAD_CURVE") {
field(DTYP, "stream")
field(OUT, "@my.proto load_curve(DEV:CURVE_FILE, DEV:VPI) $(PORT)")
record(waveform, "DEV:CURVE_FILE") {
field(DESC, "File path")
field(DTYP, "Soft Channel")
field(NELM, "256")
field(FTVL, "CHAR")
- Re: Stream device: how to send waveform of chars without null terminator? Isabella Rey
- Stream device: how to send waveform of chars without null terminator? Isabella Rey
<2015>
2025
2026
<2015>
2025
2026
