1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Stream device: how to send waveform of chars without null terminator?
To: Ralph Lange <[email protected]>
Cc: EPICS Tech-Talk <[email protected]>
Date: Wed, 1 Apr 2015 11:07:08 +0100
Hi Ralph,
Yes, but with %s the device receives something like:
load_curve 675892112117108115101461161201160 3870\r\n
The null character corresponds to the 0 at the end of the waveform (I've checked it with small strings)
Isabella
On 1 April 2015 at 10:44, Ralph Lange <[email protected]> wrote:
Have you tried using "%s" for the string output?
~Ralph
On 01/04/2015 10:44, Isabella Rey wrote:
Hi All,
I have a device to which I need to send a file path followed by a number:
example:
load_curve C:\pulse.txt 3870
The file path is stored in the database as a waveform of chars.
When I run the protocol stream device sends (what I think is) a null terminator after the file path:
device receives:
load_curve C:\pulse.txt\x00 3870
Is there any way of getting rid of the \x00 terminator?
Below I copy my protocol and the database records.
Cheers,
Isabella
I've defined the protocol in stream device as:
load_curve
    out "load_curve %(\$1)c %(\$2)i";
    in "%(\$1:\$2)b";
and in the database I have:
record(bo, "DEV:LOAD_CURVE") {
  field(DTYP, "stream")
  field(OUT, "@my.proto load_curve(DEV:CURVE_FILE, DEV:VPI) $(PORT)")
record(waveform, "DEV:CURVE_FILE") {
  field(DESC, "File path")
  field(DTYP, "Soft Channel")
  field(NELM, "256")
  field(FTVL, "CHAR")
Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
Stream device: how to send waveform of chars without null terminator? Isabella Rey
Re: Stream device: how to send waveform of chars without null terminator? Ralph Lange
Prev: Re: Stream device: how to send waveform of chars without null terminator? Ralph Lange
Next: Re: seq-2.2.1 assertion failure Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  <20152016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Stream device: how to send waveform of chars without null terminator? Dirk Zimoch
