The CS-Studio Code-A-Thon has the following tasks so far, (I'll have the website updated with a summary as people commit to tasks):
CS-Studio development environment Goal: All agree and understand the build process so that we’re able to build from sources and get the same results, everything or module-by-module. IDE build, command line build defining target platform
Configure CIoudbees Goal: CIoudbees builds everything, everybody can use the results (plugins, complete products) or, if desired, reproduce in local Hudson setup. Create common jobs on cloudbees jenkins (using Jenkins Job Builder). Re-enable the unit tests for the various cs-studio modules. Makes the jenkins jobs accessible (github repo of Jenkins Job Builder scripts).
Update Docbook Goal: Describes the above. Location of the various p2 and maven repositories associated with cs-studio Simple product build by assembling plugin/feature binaries from cloudbees. Build all of cs-studio from sources.
Modularize applications into features (Issue #818) Goal: Speed up build. Allow products to use older versions of selected features. versioning where are they hosted where should shared plugins reside
Common utility plugins remove duplicate utility classes macros dialogs and ui components (Password input #1005, Start/end time, ui pieces for VTypes) Mapping of IFile <-> File. RAP vs. RCP utils that include workspace or not.
diirt version 3 integration updated VTypes serviceloader
Java8 VType: Use Java 8 Instant instead of its own timestamp Update all other uses of time to Java 8: Start/end time dialog logging API Use Optional<> for anything that can be null. Replace “if xx == null”. Lambdas for Runnable()
Eclipse Preferences and Properties (specification for this project) Increase / improve Logging() - Error reporting and usage data gathering.
Include new Eclipse UI freeze log plugin in CS-Studio
- Registration Open for the Spring 2015 EPICS Collaboration Meeting Spring 2015 EPICS Collaboration Meeting
- Re: Registration Open for the Spring 2015 EPICS Collaboration Meeting Rod Nussbaumer
- RE: Registration Open for the Spring 2015 EPICS Collaboration Meeting Dalesio, Leo
- RE: Registration Open for the Spring 2015 EPICS Collaboration Meeting Williams Jr., Ernest L.
- Re: Registration Open for the Spring 2015 EPICS Collaboration Meeting Jack
RE: EPICS UIs in the context of changing enum record identifiers Arnold, Ned D.
RE: EPICS UIs in the context of changing enum record identifiers Mooney, Tim M.
<2015>
2025
2026
RE: Registration Open for the Spring 2015 EPICS Collaboration Meeting Emmanuel Mayssat
<2015>
2025
2026
ANJ, 16 Dec 2015 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
