Hello Anthony,
For waveform records StreamDevice repeats the format for each element
and optionally reads a separator in between. While this allows to read a
row, it cannot read a column. And it probably does not work with
redirection (I have never tried).
This makes it a bit complicated to read your device. But hopefully not
impossible. You need a few more records.
I understand that the reply always consists of 3 rows. Then I would try
the following:
Have two longin records, one for X and one for X.
Redirect to these records as you do now, but do it 3 times:
Terminator = "\n";
getTBT_XY {
out "TBT_XY 3";
in " %(\$1TBT_Horizontal_tmp)d %(\$1TBT_Vertical_tmp)d";
This processes the two longin records 3 time each. For the waveforms use
two compress records and do a FLNK from the longin records to the
compress records:
record (longin, "$(P)$(R)TBT_Horizontal_tmp")
field (FNLK, "$(P)$(R)TBT_Horizontal")
record (compress, "$(P)$(R)TBT_Horizontal")
field (INP,"$(P)$(R)TBT_Horizontal_tmp")
field (ALG, "Circular Buffer")
field (NSAM,"3")
The same for Vertical.
I am not quire sure about the compress record settings. Maybe you need
to try a bit.
Maybe you may want to write to the .RES of the compress before starting.
In that case you can use additional seq records.
Hope this helps.
Dirk
On 09.04.2015 23:01, Anthony Pietryla wrote:
I have a device which uses SCPI protocol and returns sets of waveforms
in columns where I can request how many rows to return. For instance I
can query the device for 3 values of position data and it will return 2
columns (X & Y) and 3 rows. I want to read the columns into separate
waveform records. I am having problems with the protocol file for which
I need help.
The database records and the protocol file are listed below. When I
process the record only the first values (first row of data) are written
to each record. With asyn debugging turned on the console shows all
three sets of data:
epics> 2015/04/09 13:52:36.877 L0 wrote
TBT_XY 3
2015/04/09 13:52:36.878 L0 read
2000 6000
7143 4286
4286 1429
caget shows only the first value stored:
caget -# 5 B:Spark:TBT_Horizontal
B:Spark:TBT_Horizontal 5 3333 0 0 0 0
caget -# 5 B:Spark:TBT_Vertical
B:Spark:TBT_Vertical 5 -1111 -3333 0 0 0
The protocol file has:
getTBT_XY {
Separator = "\n";
out "TBT_XY 3";
in " %(\$1TBT_Horizontal)d %(\$1TBT_Vertical)d";
ExtraInput = Ignore;
The database records are:
record(waveform, "$(P)$(R)TBT_Horizontal")
field(DESC, "TBT Horizontal")
field(DTYP, "stream")
field(INP, "@spark.proto getTBT_XY($(P)$(R)) $(PORT)")
field(NELM, "262144")
field(EGU, "um")
field(FTVL, "LONG")
record(waveform, "$(P)$(R)TBT_Vertical")
field(DESC, "TBT Vertical")
field(DTYP, "Soft Channel")
field(EGU, "um")
field(FTVL, "LONG")
When I comment out the “ExtraInput = Ignore;” line in the protocol file
I get error messages:
2015/04/09 15:53:58.170 L0 wrote
TBT_XY 3
2015/04/09 15:53:58.170 L0 asynOctetBase interrupt
2015/04/09 15:53:58.171 L0 read
3333 -1111
-3333 -5556
-2000 0
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: 29 bytes surplus
input "<0a> -3333 -5556<0a> -200..."
2015/04/09 15:53:58.271 L0 B:Spark:TBT_Horizontal: after 13 bytes:
" 3333 -1111"
Anthony Pietryla
Principal Controls Engineer
Advanced Photon Source
Argonne National Laboratory
Phone: 630-252-7430
Fax: 630-252-6123
- Re: StreamDevice reading waveforms Anthony Pietryla
- StreamDevice reading waveforms Anthony Pietryla
RE: CSS Boy and Signed/Unsigned Int Issue matthew.furseman
<2015>
2025
2026
<2015>
2025
2026
